85 Kawasaki VN700 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-17-2018, 02:00 AM Thread Starter
85 Kawasaki VN700
Alright guys i just bought an 85 ZN700 today off a real nice guy bike ran and drove but had no headlight or tailights or running lights, figured it would be an easy fix like a fuse or something along those lines, also starter wasn't catching so i figured it needed a starter no big deal, once i got it home i ran it around a bit and parked it. Went back to it a few hours later and now i have no power to the Engine shut on\off, upon some further investigation into it with a test light and what not found out i have a bad relay which was the reason for my lights not working so moved the relays around to figure out which one was bad so i could replace it, now my question is do all 3 relays need to be working in order to get power to the engine on/off? before i go get one part id like to see if i should look into other things as well.
my Name is Brandon and im about 20 minutes south of Harrisburg PA thanks for any and all input!!
FosB is offline
post #2 of 2 (permalink) Old 07-17-2018, 01:09 PM
Again, can't help you as you have a ZN 700 NOT a VN 700. Completely different motorcycles. You can search to see if there is a forum for that bike.
