Good news bad news - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 27 (permalink) Old 03-24-2009, 07:22 PM Thread Starter
Good news bad news
Well I got my TOC springs & installed them & the bike sounds much better but then it blew the main fuse & I found my RR wires melted togather I pulled them apart & seperated them all & retaped them all seperately & left them that way but the RR was already fried so I pulled the one off my non running Vulcan & put on there & it charges great but them RR wires are getting way to hot so I guess I need to do some more checking I thought I was finally gonna get to ride it more than a couple miles guess I was wrong.
99Vmax is offline
post #2 of 27 (permalink) Old 03-24-2009, 07:27 PM
Check the connections, clean if needed. Bad connections can cause the wires to get hot.
post #3 of 27 (permalink) Old 03-24-2009, 07:31 PM
Vintage bike addict
antiq's Avatar
Be sure the connection are both clean and tight the grease good with dielectric grease.
Eleanor Roosevelt.
antiq is offline
post #4 of 27 (permalink) Old 03-24-2009, 07:48 PM Thread Starter
Thanks the connector was gone when I got it & it had female spade connectors on it that were really dirty I cut them all off & put new insulated spade connectors on it im thinking maybe I should try & find the right plug for it.
99Vmax is offline
post #5 of 27 (permalink) Old 03-24-2009, 11:30 PM
HAWK
Ccspinner's Avatar
Alot of us have cut the connectors off and soldered the wires together.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #6 of 27 (permalink) Old 03-25-2009, 02:34 PM Thread Starter
I guess I can try that I just crimped the new connectors on could be part of my problem.
99Vmax is offline
post #7 of 27 (permalink) Old 03-25-2009, 02:43 PM
93VN750's Avatar
Those leads have almost 15 Amps running through them at times which will heat up the copper. Couple that with a 90 degree day and you've got loads of heat.
The strip & solder method will provide the best possible connection which will have the lowest series resistance keeping the splice the coolest. Any connector, unless you spend a ton on large diameter copper connectors, will have an amount of loss through it, need to minimize this.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 27 (permalink) Old 03-25-2009, 04:36 PM Thread Starter
Jon
I usually solder every thing guess I was feeling lazy that day. I will do it in the next few days right now I am working on a paint job on a GSXR for some one I have way to many projects but the GSXR is money I need right now.
99Vmax is offline
post #9 of 27 (permalink) Old 03-25-2009, 11:06 PM
Jon
Hey Jon --
I'm in the middle of exactly the same thing. Is it okay to use a new connector but use solder to connect each wire to each pin? Or is it better to not use a connector and go with just a soldered connection for each wire?
Thanx!
FlaRider is offline
post #10 of 27 (permalink) Old 03-25-2009, 11:25 PM
The Professor
lance328's Avatar
Originally Posted by FlaRider View Post
Hey Jon --
Thanx!
Are you talking about the R/R connector or the three stator connections?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
