LED volt meter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 7 (permalink) Old 06-13-2018, 07:48 AM Thread Starter
JETHRO's Avatar
LED volt meter
fitted a new volt meter to my vn750 to keep an eye on battery charge, looks great I think.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #2 of 7 (permalink) Old 06-13-2018, 08:24 AM
Mod
Birdhunter02's Avatar
Usually you want the gauge where you can see it while driving so you'll know when trouble starts. Is it a direct connect to the battery?
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #3 of 7 (permalink) Old 06-13-2018, 08:43 AM Thread Starter
JETHRO's Avatar
yes, its direct to battery with in line fuse, It has a mosfet rectifier fitted so charge goes straight to battery.
JETHRO is offline
post #4 of 7 (permalink) Old 06-13-2018, 08:47 AM
Always good to know what's going on with the charging, especially when deciding to ride toward home, or another 50 miles away.
As I just found out, low volts will cause backfire and rev limiting that mimics a fuel problem. Same as the backfire when cranking with a low battery.
jgs000 likes this.
post #5 of 7 (permalink) Old 06-13-2018, 10:17 AM Thread Starter
JETHRO's Avatar
yep, The symtoms are very similar and without a volt meter its hard to know what is wrong. The bike needs to have a good battery and a solid charging system for it to work properly so one glance at the volt meter tells me all is ok on electrical side ,Then its back to the long list of other probables.
JETHRO is offline
post #6 of 7 (permalink) Old 10-16-2018, 09:27 AM
Pretty! Where did you get it?
TheJabberWoggy is offline
post #7 of 7 (permalink) Old 10-17-2018, 10:04 AM
Choices are almost unlimited on ebay, all sorts of configurations.
