Get 18x1.50x60mm bolt for pulling rotor from CASE IH farm equiptment dealer - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-23-2009, 07:32 PM Thread Starter
The 18x1.5x60mm bolt needed to pull the rotor for a stator change, is a regular stocked item at Case IH farm equiptment dealers, and maybe some others too. It is about $10 US up here, about the same as online, before shipping and handling charges. Just a heads up for anyone in or near farm country, who needs one.
This is the second post with this info. I mistakenly put it in carbs and fuel first, and can`t find a way to delete it.
post #2 of 8 (permalink) Old 03-23-2009, 07:50 PM
Crobins365's Avatar
Great find, OlHoss - those are hard to come by in the States in hardware stores and such, but I'm not sure anyone's thought about farm equipment!
C
Crobins365 is offline
post #3 of 8 (permalink) Old 03-23-2009, 11:22 PM
flitecontrol's Avatar
Like so many other things, most tractors are now manufactured overseas. Another reason they are switching to metric fittings.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 8 (permalink) Old 03-24-2009, 02:34 PM
Chucklehead
dragon159's Avatar
Well .... My location pays off for something at least. I never would have thought about the implement stealers. Seeing as there's one just down the road from me I'll be taking a jog down there shortly. Good find Hoss!!
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #5 of 8 (permalink) Old 03-24-2009, 02:51 PM
93VN750's Avatar
That's what I just paid a couple of weeks ago. (http://www.motionpro.com/motorcycle/partno/08-0116/)
There's a tool that there is no substitute for. When you use it, it works so well you're amazed.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 8 (permalink) Old 11-19-2009, 12:20 PM Thread Starter
Just bumping this back to the top for anyone (replacing a stator over the winter) who needs it.
EDIT: Ignore the bit in parenthesis. Thanks for the correction seebeeare. I do know the rotor doesn`t have to come off to replace the stator, so all I can do is blame Alzheimers, Halfheimers or Oldtimers. Duh
post #7 of 8 (permalink) Old 11-19-2009, 03:59 PM
Columbus, Ohio
jimkonst's Avatar
I recently needed to pull the rotor off an 82 Honda Nighthawk 650. Honda did not have it, due to its age, and those that they had for other bikes were very expensive. I went everywhere trying to find the right sized bolt, including Tractor Supply Co. Finally I was told by a bike mechanic to use the front axle, as it is the right size and has the right thread.
I bought an axle for a couple of dollars, rather than tear apart my front end, and now keep it in my tool box. It did fit.
I don't know if this is commonly done by other bike manufacturers, but you might compare the two.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #8 of 8 (permalink) Old 11-19-2009, 06:24 PM
Simple Solutions
seebeeare's Avatar
Originally Posted by OlHossCanada View Post
Just bumping this back to the top for anyone replacing a stator over the winter.
replacing a stator? y would one pull the rotor??
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
