HELP!! Bike won't even turn over... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-23-2009, 03:36 PM Thread Starter
I have a 1986 VN 750 that was running good. I had to replace the fork seals which involved removing the headlight and all the wiring associated.. Once I got everything put back together the unit turned over once, blew a fuse and now won't turn over at all. I replaced the 10 amp fuse blown and have come to the conclusion there was a bare wire in the headlamp casing... After correcting this the starter will not turn at all. Any ideas what the problem could be? I've traced every wire to make sure there were no breaks but I still get nothing. The battery is fully charged, all the lights come on but when the start button is pushed nothing happens... Help, please!!!
madnoey3 is offline
post #2 of 6 (permalink) Old 03-23-2009, 03:55 PM
On His Lady Vulcan
wkrizan's Avatar
Recheck all fueses again, main fuse (30amp) mainly, make sure that you didnt cross a wire or two when you reassembled. I have personaly done that myself I am sure others will pipe in with a few more ideas for you, untill then check out those couple things. Good luck and keep us posted on your progress.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #3 of 6 (permalink) Old 03-23-2009, 04:31 PM
Don't mean to sound dumb but check the kill switch on the handlebars . I drove 40miles for my neighbor because he said his was dead and found he accidently hit the kill and all I did was turned it back on.
Rebel is offline
post #4 of 6 (permalink) Old 03-23-2009, 05:14 PM
Concert connoisseur
wib714's Avatar
I did that once too, pulled into town and it was cold and ready to rain so I had on thick leather gloves and bumped it and didnt realize it, I was two blocks from work so I started pushing it, got about a block and realized the switch was off. boy did I feel stupid!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 6 (permalink) Old 03-23-2009, 05:32 PM
X2 to Rebel^^^^
Also double check neutral light/switch, clutch safety switch, and sidestand switch.
Are you getting power at the start switch button, both terminals, and from the starter switch (trigger) wires at the relay? Try jumper wire direct from battery pos terminal to pos trigger terminal on relay. Does the relay click? If you have power at both trigger terminals but the relay does not click, it is bad. If no click, try jumping the contacts across the relay or directly from the battery positive terminal to the starter terminal. If the relay doesn`t click but the jump turns the engine over, the problem is in the relay. Let us know what you find. If you need more help, just ask.
post #6 of 6 (permalink) Old 03-23-2009, 06:50 PM
which 10 amp fuse did you blow?
