Page 1 of 2 | 1 | 2 |
Hello!!
what keeps makes the bike want to turn over, goes super slow, and then gives ame a series of clicks?
-Zach
Sponsored Links | |||
Weak battery. We all use AGM batteries as standard wet cells don't work well on this bike.
The clicking means a dead battery or loose battery/starter connection somewhere. Combined with slow cranking beforehand, I'd say dead battery.
even hooked up to a running car battery it didn't turn over, it took forever to slow start, and it was extremely slow cranking over, then cranks over, now its a fast start but goes straight to clicks. battery is ruled out
-Zach
Originally Posted by TeamGreen
View Post
It shouldn't be jumped from a running car, that can cook the rectifier on the bike.
just for the sake of argument, rule out the battery. it was brand new. not battery, what causes the clicking sound? again its not the battery!! i say again, it was a slow crank, and i know u wanna say battery cause it was slow, but isnt the starter/or solenoid the one thats suppose to do the cranking?
-Zach
View Post
Either from a weak/dead battery, or a loose connection.
Good luck!
edit: The starter does the cranking, but it takes amps from the battery to make that happen. Low amps = slow cranking. In the case of a worn out starter, the starter pulls more amps than even a fresh battery can supply.
I wouldn't suggest a new starter until the battery is load tested.
Yeah. What he said.
Vulcan slang for newcomers
Service Manual Download
Oh TeamGreen, the contactor or solenoid on these bikes seems to drop out around 11.5 volts. So it has to have a really good battery and voltage supply.
That being said, I did jump mine off numerous times with my truck and didn't know it could damage the RR. It cranked fine like that with a known bad battery. So I'm not sure it's your battery, but could be a bad starter or bad connection.
ALSO, if your carb is flooding or your tank petcock valve is bad, it could flood your front cylinder and act like a weak battery / bad starter / bad connection etc... because the front cylinder is attempting to compress liquid. Ask me how I know...
-2016 Indian Springfield
Chieftain bars
Roadmaster heated seat
-1999 Kawasaki Vulcan 750
Ear shaved
Mufflers removed / 38/140 + 2 shims
Relay coil mod
Pick-up coil mod
Emissions removed
Lowered rear
Rear blinkers located in tail light housing
Petcock gutted
- Wife's: 2018 Can-am Spyder F3 Limited Pearl White
ok bingo, im with you on that, b/c i made sure the battery was charged, replaced the sparks plugs and they were rich. it started after several cranks, and then i went to go put some pants on so i could test ride, and dammit to hell it wouldn't crank over again! it sputtered twice, and then the battery caved, again. what do? seriously im bugging out...
-Zach
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
