fusing stator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 03-19-2009, 11:10 AM Thread Starter
fusing stator
I have seen a few of you have fused the stator on your bike ,do you put the fuses in the three stator wires?If so how many amps ? sounds like extra protection to me and I am thinking about it.
post #2 of 14 (permalink) Old 03-19-2009, 11:20 AM
letitflight's Avatar
I need to do the same to man!
the connector are starting to melt slowly due to the heat generated by the engine.
Vulcaneers! we need some help here
Thanks
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #3 of 14 (permalink) Old 03-19-2009, 11:29 AM
Chucklehead
dragon159's Avatar
I did mine out of laziness. The connectors were going bad and I had the holders just sitting around. Each one has a 20A fuse in it and they go on on each of the yellow wires coming from the stator to the R/R. It also made it easier to relocate the R/R.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 14 (permalink) Old 03-19-2009, 11:32 AM
Thanks!
PEACE!!!
2005 Vulcan 750
post #5 of 14 (permalink) Old 03-19-2009, 12:34 PM
The Professor
lance328's Avatar
Before you fuse the stator, read the link below!!!
https://www.vn750.com/forum/showthrea...ht=stator+fuse
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 14 (permalink) Old 03-19-2009, 12:49 PM
Hmmm, I thought I posted something similar to the post Lance linked to, but I must've just hit 'Preview Post'?!
IMO, fusing the stator is no way to assure you wont have problems
post #7 of 14 (permalink) Old 03-19-2009, 01:11 PM
93VN750's Avatar
I posted in that thread and still remain convinced that a properly connected voltmeter is your best ally.
I will not be using the fuses when I reinstall my engine. I will be using as high a quality splice as possible to minimize the series resistance which can cause the joint to melt. Most likely twist leads together and then solder, and then black tape wrap.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 14 (permalink) Old 03-19-2009, 02:22 PM
Calif Rider
weh44att's Avatar
There are a lot of different opinions on this subject, you will have to form your own. I fused mine also when the wires at the RR started to get to hot and melt the wire. At that time I had a bad RR I think, replaced the RR, but still have it fused, with 20
AMP fuses. The old RR use to get really hot, could not hold on to it no longer than about 4 seconds after a long ride.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #9 of 14 (permalink) Old 03-19-2009, 02:45 PM
Originally Posted by 93VN750 View Post
.... Most likely twist leads together and then solder, and then black tape wrap.
When I do stranded wire joints, I usually make two ends on each wire (seperate the strands into two ends), twist each set of two, then twist those two into one. Alot stronger and more surface to surface contact.
post #10 of 14 (permalink) Old 03-19-2009, 02:51 PM
this is the proper technique to solder two wires together btw
