Starter Relay - 2 pin connector - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-13-2018, 06:08 PM Thread Starter
TechMech's Avatar
The starter relay has a two pin electrical connector with a B/Y wire and a Y/R wire. Does it matter how the connector is connected since it can be turned over and connected either way? Got a little forgetful when replacing the relay.
TechMech is offline
post #2 of 4 (permalink) Old 05-13-2018, 08:33 PM
WilliamTech3's Avatar
Cool
EDITED;
As if sitting on bike looking down at mine from above, with Battery Cable and Cable to Starter connections near the top, the lower smaller two pin white spaded connector has the B/Y towards rear of bike, the Y/R on terminal towards the front of bike.
....hope this helps
WilliamTech3
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
post #3 of 4 (permalink) Old 05-14-2018, 05:12 PM Thread Starter
TechMech's Avatar
Thank you for your response. I don't know if your relay is mounted differently, but mine is mounted on its side. Sitting on the bike looking down, all of the connections are pointed toward the rear of the bike. Let's try this: Looking at the connections on the relay with the two "spade" connections below the two "pole" connections (the two pole connections being the battery cable and cable to the starter connections), which wire would be on the left and which on the right? Sorry to take so much time with this but I appreciate your help.
TechMech is offline
post #4 of 4 (permalink) Old 05-14-2018, 08:47 PM Thread Starter
TechMech's Avatar
I looked at the relay again and now think I understand when you described the battery cable and cable to starter connections "near" the top. They are more in the middle and the connections I am concerned about are at the bottom. So B/Y would be on the left and Y/R would be on the right. It turns out I understood your original post well enough. Again, thanks.
TechMech is offline
