Battery Voltage = 12.5 volts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 46 (permalink) Old 03-15-2009, 06:00 PM Thread Starter
Howdy Folks --
GOOD NEWS:: With the help of this forum, today I bought a Multimeter and
used it for the first time ever to find a problem with the Junction Block!
BAD NEWS:: I think I may have uncovered another electrical problem
Just for kicks I measured the voltage across the battery terminals = 13 volts with the bike turned off. I then started up the bike and measured across the terminals again while idling or reving the engine to about 6k rpm made no difference = 12.5 volts.
I thought I read somewhere that when you rev the engine the voltage should read about 14 to 15 volts?
I have a MF battery installed by the PO about 2 years ago. I do mainly short rides near home. Each evening I connect the bike to a battery tender plus and each morning the tender gives a green blinking light indicating the battery is charged. I may have an electrical problem and not know it.
Does this indicate a bad stator and/or R/R. What should I do next?
Sorry to be the bearer of constant bad news but I'd be lost without this forum. With your help one day maybe I will get Mr. Spock back in good Vulcan health!
FlaRider is offline
post #2 of 46 (permalink) Old 03-15-2009, 06:06 PM
The Professor
lance328's Avatar
Originally Posted by FlaRider View Post
Howdy Folks --
Pull the connector off the R/R and set your multimeter to AC volts. Start the bike and measure the voltage of the three yellow wires, check two at a time.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 46 (permalink) Old 03-15-2009, 06:33 PM
as lance said, just adding to it...when you check the wires go through the rpm range and the ac voltage should increase. if not then the Stator is at fault...also in the clymer manual there is a R/R torubleshooting flow chart...check all readings acrossed the r/r and compare with the manual. it could also be something as stupid as a bad ground or the jb as well... I was having a charging issue last year that ended up being a bad JB...I replaced the JB for another problem, and it just happened to fix my charging issue.
post #4 of 46 (permalink) Old 03-15-2009, 08:59 PM
93VN750's Avatar
In addition to above tests, check from each yellow lead to the engine case. Should read infinite, if not your stator is bad.
When the stators fail, the insulation breaks down allowing the stator wire to contact the stator core, this shunts any power immediately to ground, nothing goes to the r/r or battery.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 46 (permalink) Old 03-15-2009, 10:34 PM
Now what
Ironman's Avatar
Go to this page and download the electrical fault finding guide. http://tinyurl.com/c2zou It'll help you track down the problem.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #6 of 46 (permalink) Old 03-15-2009, 10:48 PM
Love My Baby
rubyrick's Avatar
Also, normally there is no need to connect a battery tender to your MF battery EVERY NIGHT. Your battery should hold a charge for a long time, and you should only need to charge it infrequently. In your case however, if you have a bad charging system, charging your battery nightly might have kept you going and hidden the problem for quite a while.
Caution to those with non-maintenance free batteries: Don't connect a battery tender or other charger every night to your battery because the initial charging, even with a battery tender, will cause you to loose some fluid through the vent tube. Then before you know it your battery fluid level will be VERY LOW. You simply MUST check your battery fluid level monthly if you charge frequently, or you WILL be S.O.L. before you know it. And checking this is a royal P.I.A.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #7 of 46 (permalink) Old 03-15-2009, 11:12 PM
The Professor
lance328's Avatar
With a non MF battery you have to check the fluid levels every month anyway, pluged into a charger or not because of the bikes normal charging.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 46 (permalink) Old 03-16-2009, 01:33 AM
Love My Baby
rubyrick's Avatar
Good point. All non-MF batteries should be checked for proper fluid levels monthly, wether or not you charge them frequently, or you WILL be stranded somewhere some day.
All MF and non-MF batteries should have their voltage checked monthly to be sure they are holding a charge well. Even MF batteries die out... they just don't loose fluid as much.
I have a battery tender quick connect cable attached to my MF battery and tucked in under the side of the seat. It's quick and easy to check the voltage by untucking the cable and connecting a voltmeter.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #9 of 46 (permalink) Old 03-16-2009, 02:02 PM Thread Starter
Hey Lance, Slim, Jon, Ironman, and RubyRick --
Thanx for the great response! I will follow-up on your tips.
It will be a couple of days before I can work on the bike but I will post an update within 3 or 4 days.
My thanx to all!!!
FlaRider is offline
post #10 of 46 (permalink) Old 03-19-2009, 12:33 PM
So, I just bought my son a '93 750.
I find this web site, (cool place), look at this posting and run home and fire up his bike.
I thought I had a bad stator, (the sons-of guns! They said they repalced it when they did the motor!),as with it running I got 12.5 volts.
I looked at my old 800 vulcan shop manual, for a "kinda idea", (the 750 shop manual is on order).
I run the tests, fire it up and then it hit me!
They say to test the output voltage with the head light fuse OUT!
So I do and sha-zam, 13.8 volts.
Makes sense, as long as it is about 12 volts with all the lights on, it's cool!
Just 1 old guys thoughts,
Joe
I ride therefore Iam!
joe28 is offline
