Engine won't crank, tried everything
Battery is fully charged. Opened the starter and made sure there was a spark. All the obvious stuff like ignition, neutral, kickstand, cutoff switch, clutch not the issue. The horn and headlights work fine.
The problem started when my bike tipped on its side after I rode over some gravel. It only started up once more after that so I could ride it home.
Any ideas? What other things should I troubleshoot?
Thanks!
Thanks!
Sponsored Links | |||
Originally Posted by Leo Kirsch
View Post
Thanks!
Thanks!
If so, Squirt some juice down the carbs....if cylinders fire then it is a fuel problem.
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
clarification needed..
wont crank=engine does NOT turn over with the starter when trying to start.
wont start=engine will not start, however it is turning over when start button pressed
2 totally different issues
Originally Posted by michiganteddybear
View Post
But need clarification on the above questions.
Which side did it land on?
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
