Frustrated::Headlight Still Out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 03-14-2009, 12:37 PM Thread Starter
Angry Frustrated::Headlight Still Out
Howdy Folks --
I need your help. My headlight is still out. (I restarted this thread from the General Discussion)
HISTORY:
* About 1 week ago blew main fuse and replaced it
* Bike ran fine after main fuse replacement but headlight was out
* Checked all fuses--they're all ok
* Cleaned connections on RLU (Reserve Lighting Unit) back of battery box
* Replaced headlight bulb and checked for frayed wires inside headlight
* Visually checked for frayed wires on harness around battery area
How can I get the headlight to work so I can RIDE AGAIN!!
Thanx in advance!
FlaRider is offline
post #2 of 20 (permalink) Old 03-14-2009, 01:09 PM
The Professor
lance328's Avatar
Have you checked the ignition switch and the start button? Remove HL fuse and with switch on check to see if th HL fuse socket has power. You may have a JB problem.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 20 (permalink) Old 03-14-2009, 01:18 PM
I just finished doing a search on your problem through the forum....90% of people with your problem replaced the JB and fixed the issue...the other 10% had fried stators. So I would check the blue wire coming out of the JB for VDC, if it is anything less than your battery voltage then the JB is defective. If it is Battery Voltage then make sure you are getting the correct voltage out of the RLU.
inside the headlight bucket there are two open sockets, one is ground, one is hot (W/L). make a jumper wire and hook it up to the hot (W/L) connector on one end then jump it to the R/Y connector. (Unplug the R/Y wire before connecting the jumper wire.)
post #4 of 20 (permalink) Old 03-15-2009, 04:43 PM Thread Starter
Smile Junction Box Culprit--
Hey Lance and Slim --
You guys were right on the money!!!!
It's a JB (Junction Box) problem. The HL fuse socket has no power, but all of the other sockets do.
I have the part# off of the JB: 26021-1064. Should I replace the JB with a new or used one?
You folks are amazing!!!!!
""Have you checked the ignition switch and the start button? Remove HL fuse and with switch on check to see if th HL fuse socket has power. You may have a JB problem.""
FlaRider is offline
post #5 of 20 (permalink) Old 03-15-2009, 05:17 PM
The Professor
lance328's Avatar
Either one will be fine, it's your choice. A new on will be around $115.00 and used about half of that.
http://cgi.ebay.com/ebaymotors/1995-...Q5fAccessories
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 20 (permalink) Old 03-15-2009, 05:29 PM Thread Starter
Many Thanx, Lance!
I think I'll go with this used one!
FlaRider is offline
post #7 of 20 (permalink) Old 03-15-2009, 06:35 PM
if the used one seams to be a dud...you can open up both the JB's and unsolder the relays and diodes and put them onto the other board...wich ever board looks better.
post #8 of 20 (permalink) Old 03-16-2009, 01:49 PM Thread Starter
I'll definitely keep that in mind.
Thanx again, Slim!
FlaRider is offline
post #9 of 20 (permalink) Old 03-16-2009, 02:03 PM
So was the $40 winning bid yours? Glad you found the problem.
post #10 of 20 (permalink) Old 03-16-2009, 02:03 PM
The Professor
lance328's Avatar
Thanx again, Slim!
That used one says it has been tested, did you check the stator voltage?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
