LED questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 2 Post By DenverDiesel
post #1 of 6 (permalink) Old 03-14-2018, 11:12 PM Thread Starter
PlanetVulcan510's Avatar
LED questions
Has anyone converted the dash lights, idiot lights, whatever you call em, to LEDs. What do I need as far as resistors ext.
PlanetVulcan510 is offline
post #2 of 6 (permalink) Old 03-15-2018, 04:11 AM
Diesel Tech
DenverDiesel's Avatar
Headlight H4/9003 x1
Turn/marker front 1157 x2 amber, 1.5" max length
Turn rear 1156 x2 amber, 1.5" max length
Brake 1157 x2 red, 2" max length
Plate 67 x1, 1" max length
Speedo/Tach/Temp/Fuel backlight 74 x5
Turn indicate 194 x2 amber
Oil psi 194 x1 red
Neutral 194 x1 green
High beam 194 x1 blue
Headlamp fail 194 x1 white
The bulbs are all plug-n-play.
This headlight fit perfectly in my housing and puts out really good light. https://www.amazon.com/gp/product/B0...ilpage_o07_s00
You will need a capacitor to filter alternator noise (ripple) that could cause light flickering at idle. https://www.bandc.aero/electrolyticfiltercapacitor.aspx
You will need an LED specific flasher. https://www.amazon.com/gp/product/B0...ilpage_o06_s00
Paulywog and Thorn like this.
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #3 of 6 (permalink) Old 03-15-2018, 08:00 AM
that flasher may work, (I dont know specifics on it), but an EP34 from local parts store will plug and play and is under 20 bucks. I believe our flasher is only 2 pin
michiganteddybear is offline
post #4 of 6 (permalink) Old 03-15-2018, 09:56 AM
Diesel Tech
3 pin.
But 2 pin will work fine. The third pin is just dedicated ground for the electronic controller.
1989 VN750
Highway blaster
1982 Mercedes 300D
post #5 of 6 (permalink) Old 03-25-2018, 12:39 PM
I'm a rider
One1's Avatar
I'd recommend using leds in your headlight, running lights, brake, and turn. Would not recommend them anywhere else. Bright gauges and indicator panel lights are annoying distractions from the road. On top of that using them in the gauges isn't even lighting across the lens and looks janke. I owned a company for 14 years that modified gauges for cars to convert to led and I've argued with every fool on the planet that says his lights up evenly so when he goes and takes a pic to post with reasonable contrast, not blown out, it looks like hell. We had to modify the leds and clusters both to get them looking good. The problem is twice as bad with motorcycle gauges.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #6 of 6 (permalink) Old 03-25-2018, 09:49 PM
Diesel Tech
LED technology has changed dramatically even in the last 2-3 years.
When I bought sealed beam LED headlights for my car 5 years ago they were $250 each with only two 1 watt elements each. They looked and light (and still do) fantastic, FAR better than any sealed beam incandescent headlight. But today I can get LED headlights for a fraction of that price that perform even better.
14 years ago might as well have been the stone age. Doing these kind of light conversions in 2004 would have been massively expensive and low quality. Comparing what you were doing so long ago to what is available today is not valid.
That said, you must be picky when buying LEDs as there is a large variety in quality and price.
1989 VN750
Highway blaster
1982 Mercedes 300D
