No auto shut off on turn signals this year... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 03-07-2009, 03:44 PM Thread Starter
Unhappy No auto shut off on turn signals this year...
Last year they worked perfect...this year so far...I find myself cruising around with the signal on...
Common problem? Easy fix?
I do have LEDS...but they worked fine all last year...
Custom Cow is offline
post #2 of 14 (permalink) Old 03-07-2009, 11:43 PM
My bike doesn't have them, but IIRC, it's a common problem with them not working after awhile. I have no idea of how (or if) they can be fixed once they quit working
post #3 of 14 (permalink) Old 03-08-2009, 06:50 AM
750Doug's Avatar
There's a solenoid in the handlebar control assembly, that is controlled by a little "module" that is mounted in the battery box area. (sorry I can't think of the specific name or location)
I've seen posts around here about changing that module, though it is pricey, and I may have save the link for it in my computer. (will try to find it)
Also it is possible that the spring around the solenoid plunger (in handlebar control assy) has broke and jammed the plunger. This happened to my bike.
750Doug is offline
post #4 of 14 (permalink) Old 03-08-2009, 07:15 AM
750Doug's Avatar
I found it, but please note...I'm sure there are other choices, suppliers, and costs out there. I just happened to stumble across this link in a thread I was reading and saved the link in case I ever needed it, and am sharing it here because it is one answer to the original post, and not uncommon.
Anyway;
signalMinder Notes
■ Automatic turn signal cancellation
■ Running light option built-in
■ Brake flash and override option built-in
This new version has all of the
RUN/TURN/BRAKE features - BUILT-IN!
No need to buy another controller!
Turn Signal Cancellation
750Doug is offline
post #5 of 14 (permalink) Old 03-08-2009, 08:27 AM Thread Starter
So it runs on a timer...?
My speedo cable is broke...but I dont see how they would connect...
But I do remember last year when I had the cluster off, and running a mini speedo, I had no shut off till I put the cluster back on
post #6 of 14 (permalink) Old 03-08-2009, 08:31 AM
At Least I Can Spell!
msh1156's Avatar
I'm not paying 100 bucks to do something my thumb can do so simply.
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #7 of 14 (permalink) Old 03-08-2009, 08:39 AM
750Doug's Avatar
Yes, a timer activates the solenoid in the bar control. If you open the control assy, (2 screws) and look inside, it'll become crystal clear.
750Doug is offline
post #8 of 14 (permalink) Old 03-08-2009, 12:08 PM
the doctor
billryx's Avatar
The Turn Signal Control Unit (back side of battery box) is triggered by the turn signal switch, counts for 4 seconds, then measures about 50 meters by the rotation of the front wheel through the speedometer. If your speedometer cable is broken then that is the first item I would replace.
bringing together
a dead
'86 VN750
"it's alive":"krechure"
billryx is offline
post #9 of 14 (permalink) Old 03-08-2009, 03:46 PM
The Professor
lance328's Avatar
As Bill said, replace you speedo cable and it should work after that.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 14 (permalink) Old 03-08-2009, 05:45 PM Thread Starter
Thanks....I shouldve caught that...that little bar lite must be some sort of sensor then...
