Installing a stator - frame cut method - Page 4 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 9Likes
post #31 of 41 (permalink) Old 05-30-2018, 09:38 AM
vulkan's Avatar
OK was asking about that "smaller" three screw cover...see its off in the pic.But was told NO NEED to remove(??)Raining here so might not get to the fix.
vulkan is offline
post #32 of 41 (permalink) Old 05-30-2018, 04:18 PM
ubertalldude's Avatar
Originally Posted by vulkan View Post
I would really think those welds gotta be Superman strong cause the way you cut that frame the kickstand HAS to hold the weight of the bike,know what I mean?
you had better be a damn good welder to consider cutting and re-welding your structural frame back together. If you can't weld like a professional welder, I would never ever consider doing this. I've pulled the engine before, it sucks, but it beats causing structural damage to your motorcycle which could potentially prove fatal. That frame rail is absolutely critical to the structure of the bike.
was told NO NEED to take the smaller three screw cover off.
to replace the stator I don't think you need to remove it, it only allows access to the pickup coils.
roadpouring likes this.
Earshave+Rejet (38/135) Ė NGK Iridiums Ė MCCT Conversion Ė Slipstreamer S03 Windshield Ė Custom Extended Backrest Ė Custom Highway Bars Ė MOSFET R/R Ė LED Underglow Ė Volt+USB In-Dash Ė Two-Wire & Blue-Wire Mod Ė Satin Black Engine Paint Ė Dampers Parts - Jets: Main=99101-393(#132 stock)/Pilot=n424-22 Pilot(#38 stock)
ubertalldude is offline
post #33 of 41 (permalink) Old 05-30-2018, 08:14 PM
It'll dance around like a combination of bad swingarm bearings, steering bearings and front wheel bearings. Do not ask me how I know kinda like having sex with a meth whore on payday
post #34 of 41 (permalink) Old 06-01-2018, 10:57 AM
good times
little ugs's Avatar
awesome job one1
little ugs is offline
post #35 of 41 (permalink) Old 06-01-2018, 11:05 PM
Still not a job for one who is not a good welder.if you know what you are doing,then ok.but is the extra time saved by not taking out your motor worth your life???
post #36 of 41 (permalink) Old 06-04-2018, 04:51 PM
vulkan's Avatar
"...is the extra time saved by not taking out your motor worth your life???" Yes,yes it is. So cut my frame today,took like a brief moment.Those (cover) screws are different lenghs,no mention of this either.Finally got that cover off there,needed a little convincing (tapping with hammer)....dropped that cover what to my surprise(!!)the Stator is attatched to the back side of the cover with some "funky" screws!!Also those suckers were tight!!Thought that the Stator would remain in that spot on the engine,had no idea it was screwed into the cover...no-one seemed to mention this here.Also there was a tiny Zip tie holding wires together in there needed cut,no-one mentions this either..
vulkan is offline
post #37 of 41 (permalink) Old 06-04-2018, 06:16 PM
It's pretty much given that side case screws will be different lengths. Yup, be sure and put the zipties back.
post #38 of 41 (permalink) Old 06-04-2018, 11:07 PM Thread Starter
I'm a rider
One1's Avatar
It's been in every DIY I've ever read on here. Not sure which DIY you're using.
I've replaced my stator a few times, but used a DIY on here to do so the first time and it was very detailed. Given that you didn't know anything at all about the stator (how it's mounted, what it's mounted with, what it's mounted to.......) I'd gather you didn't read any DIY's on stator replacement. The one's on here are very handy for people working on their bikes. I put up a couple pictures of how I cut my frame, but didn't say a word about a single bolt on the bike relating to the stator because...... it's a thread on how I cut my frame. Not only is it not a DIY, it's not even a how to cut a frame. It's a pic of how I did mine. Make a thread on your project and show folks how it turns out and what you did.
OleDirtyDoc likes this.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #39 of 41 (permalink) Old 02-06-2019, 02:35 PM Thread Starter
I'm a rider
One1's Avatar
Unseasonably warm weather in the south for the last couple of days has given me the opportunity to get the bike out wash it and ride a little bit. itís been put up since November. It is the one-year anniversary of doing this install and it has been absolutely fabulous. Iíve had no issues whatsoever and today I am pulling back some paint to check the structural integrity of the frame and there is no wear, no cracks, no issues whatsoever. Iím very happy with this mod. 10/10
Also on a sidenote this ricks stator has been absolutely flawless with over 14 V at idle and no degradation whatsoever since I installed it. Iíve put 6500 miles on it.
Clickable thumbs below.
kryptonianjorel likes this.
1981 KZ750
One1 is offline
post #40 of 41 (permalink) Old 10-03-2019, 01:19 AM Thread Starter
I'm a rider
One1's Avatar
Time to put it up for the year. This is over a year and a half update. Ricks stator is a beast, totally awesome. Still crankin 14v below 1k rpm. Frame cut method is still the best mod Iíve done. I still donít recommend it for anyone that doesnít weld above a shadetree level, and in such case you donít know which side of the fence youíre on...... if you have to ask how to do it, thereís your answer. definitely a viable solution for certain VN owners. I love it.
1981 KZ750
One1 is offline
