ignition switch and a loom problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-05-2009, 12:43 PM Thread Starter
hi. just bought the vn 700 1989. its been laid up for couple of year. so bought as non runner... No prob new fuel
press starter hey presto... No such luck.
so been on the forum looking for as much info as i can get.
Basically the prob is no spark.
was a spark, and it fired up. then cut out, fired up again then cut out, and has now gave up the ghost...
opened the loom (wire harness) up and going through all the wire stuff with metre. mostly guess work...
m8 came up who's a little bit handier and checked the ohms on pik up etc. scratched head had a coffe then went home
confused. lol...
Anyway a new prob has arose.
ignition switch on. yb wire on the loom shows 12volts. turn ignition off and i get continuety (buzzing sound from metre)
to frame. as i would expect, earth.
so i disconected the ignition bit from the loom and took it apart, looks ok, cleaned terminals
and put backtogether. no luck.
if i disconect the block bit on the ignition lead and leave the two seprate wires in, the voltage jumps
from 1 to 5 volts on the
ground wire...
Is my ignition switch caput? they look basic so what goes wrong.
wired wrong somwhere in the loom?
somthing else burnt out and causing this?[/B]
other than this be a good bike wen it gans...
any help be greatly appreciated...
scotiaredd is offline
post #2 of 12 (permalink) Old 03-05-2009, 01:12 PM
flitecontrol's Avatar
What's a loom?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 12 (permalink) Old 03-05-2009, 01:22 PM
I believe loom means the bunch of wires running together and wraped with tape.
post #4 of 12 (permalink) Old 03-05-2009, 01:26 PM
OK. Figured it meant something like that. Never heard the term before.
"Black Beauty"
Old Blue
post #5 of 12 (permalink) Old 03-05-2009, 01:29 PM Thread Starter
loom, yep its the wire harness...
post #6 of 12 (permalink) Old 03-05-2009, 03:19 PM
I believe the corrugated plastic hose with a slit down the length of it, that protects the wiring harness is called a loom.
post #7 of 12 (permalink) Old 03-05-2009, 03:31 PM
If I understand you correctly, you bought an old bike that hasn't run for a few years. You tried to turn it over and it did, and it fired (weakly) a couple of times. But, now it'll turn over, but won't fire at all.
I think your problem is probably the same as mine (situation is exactly the same - bike not run in quite awhile)...
Don't chase electrical bugs, if the bike has spark.
Take the carburetors apart and clean the crap out of the bowls.
See my thread: https://www.vn750.com/forum/showthread.php?t=9928
1st, pull out one plug at a time, clip it into the plug-wire and hold the tang to ground while cranking the engine. Do you see spark? Move to the next plug.
If all the plugs have spark, it's likely plugged jets in the carbs causing your problem. (Modern fuel is surpisingly quick to leave behind crystalline deposits.)
If all the plugs don't have spark: Ohm-test the Regulator, the stator, and the ignitor.
IIonPilgrimg is offline
post #8 of 12 (permalink) Old 03-05-2009, 04:40 PM Thread Starter
no spark to the plugs. ive tested the pulse coil, not tested stater yet will do that next. Like i said was working fine but like a switch of has happened. all lights were working, indicators horn etc. But now only the neutral light and oil light come on. Plus the ground wire is showing 12 volts running through it, need to find out if there is a short somewere on the harness... Maybe ignition switch or somthing.
cheers for advice... next will be to clean carbs out. soon as get spark back
post #9 of 12 (permalink) Old 03-05-2009, 06:06 PM
Chucklehead
dragon159's Avatar
Make sure to check the wires leading to the switch that run next to the headstock. I know of a few here that have had the wires worn through there and given problems.
In another thought, maybe there's a member close enough to you to give a hand and second set of eyes?
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #10 of 12 (permalink) Old 03-06-2009, 07:38 AM Thread Starter
cheers. took the switch of altogether and opened the wires up. underneath the switch i see a couple of wires have been soldered. so i suppose good place to start... still cant work out were the voltage is coming from on the harness (Ground wires arre live) certaintly missin somthing.
Heading of to mates on saturday see if we can sort it out...
cheers dragon159...
