Idle Adjustment Knob wanted - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 02-26-2009, 09:32 PM Thread Starter
ryn
Can't see spending 60+ dollars on a new one from the dealer, so before I stick the carbs back in I figured I'd see if anyone has an extra or some sort of tip/hack that works just as easily/well.
after 6 months I'm almost there...
ryn is offline
post #2 of 4 (permalink) Old 02-26-2009, 10:01 PM
The Professor
lance328's Avatar
You can use a small Potentiometer Knob similar to the one below. you may have to grind the hex head on the idle assy. and epoxy in place. You might find one at radio shack with a set screw to modify.
http://cgi.ebay.com/VINTAGE-ALLEN-BR...3286.m20.l1116
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 02-27-2009, 06:23 PM
oglejust's Avatar
ive got 1, do u need the whole thing or just the knob?
.... slightly modified
oglejust is offline
post #4 of 4 (permalink) Old 02-27-2009, 10:39 PM Thread Starter
ryn
I'm not 100 % sure what it is supposed to look like but all I had was half a bolt attached to some wire. the pictures in the fiche's make it look like one assembly that goes into a 90 with a knob on one side and the bolt on the other, I have nothing that I can even make resemble that. So I guess I need the whole thing.
ryn is offline
