ebay - engine guard - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By shark88
  • 1 Post By Iceshot
post #1 of 7 (permalink) Old 09-16-2017, 09:46 AM Thread Starter
ebay - engine guard
Saw this the other day, good price if anyone's looking. not mine.... Click here
LandyLou likes this.
post #2 of 7 (permalink) Old 09-18-2017, 01:22 AM
Just picked it up, thanks for the heads up Shark88!
1993 Vulcan 750 "T'Pol"
Cobra Full Exhaust (Single Sided)
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Sunpie 7" LED Projector Headlight / KZ750-B 76-79 Bucket & Trim
Full LED Bulb Conversion
Mustang Wide Regal Seat
Aftermarket Grips & Mirror's
Full Chrome Tach / Speedometer
Mobil 1 75-90 Synthetic Gear Oil
Rotella T6 / Bosch 3323 Filter
Iceshot is offline
post #3 of 7 (permalink) Old 09-21-2017, 10:46 PM
Guys, click on the link that Shark initially posted (see first post). Is this REALLY a factory issued Crash bar? Looks a lot different than every pic I've seen of the ones found on the VN750. Is the one pictured a aftermarket one? I'm confused, insights / feedback welcome!
(BTW I now own the the bar pictured)
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Iceshot is offline
post #4 of 7 (permalink) Old 09-21-2017, 11:19 PM
Arrow
Yep, you're right. Mount tabs are different and the center bars are curved differently.
The one below is missing one mount tab, but it's different all over.
G KAWASAKI VULCAN VN 750 1999 OEM ENGINE CRASH BAR | eBay
post #5 of 7 (permalink) Old 09-22-2017, 10:11 AM
Mystery solved, the bar I have is a Wingerline and it is indeed a VN750 crash bar (see link below)!
http://www.gcextreme.com/VULCAN750/E...ard/index.html
No idea what bolts, washers, and spacers (if any) I require to mount this up (sigh).
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Iceshot is offline
post #6 of 7 (permalink) Old 09-22-2017, 12:48 PM
Wingerline, yep that's the one. Good sleuthing. Good eye too, I didn't see it first time around.
Looks like it might use a different mounting point at least on one side. Maybe you'll get lucky and it will be easier than the other one. One tab was pointing down at an angle, and it's mate on the other side kind of pointed straight out.
post #7 of 7 (permalink) Old 09-23-2017, 09:43 AM Thread Starter
Yes, the Wingerline is a lot harder to find. You should be able to hold it up to the frame and get a good idea where the mounting points are. Maybe someone on here has one and can post some pictures if you can't match it up. Should be fairly simple though, not a whole lot of places to bolt on to.
