WTB Dampers!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-29-2017, 03:18 PM Thread Starter
Matthew Wellington's Avatar
WTB Dampers!!
I have called around like crazy and apparently these are no longer being supplied by the manufacturer. I received the same call about the alternator gasket and bevel gasket. I need these bad, if you do not have a set for sale then please refer me to where I can get these. Thanks for your time.
Matthew Wellington is offline
post #2 of 7 (permalink) Old 07-29-2017, 03:51 PM
Got you covered!
92075-1748 DAMPER
92075-1747 DAMPER
You need 4x of 1747
You need 2x of 1748
1993 Vulcan 750 "T'Pol"
Cobra Full Exhaust (Single Sided)
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Sunpie 7" LED Projector Headlight / KZ750-B 76-79 Bucket & Trim
Full LED Bulb Conversion
Mustang Wide Regal Seat
Aftermarket Grips & Mirror's
Full Chrome Tach / Speedometer
Mobil 1 75-90 Synthetic Gear Oil
Rotella T6 / Bosch 3323 Filter
Iceshot is offline
post #3 of 7 (permalink) Old 07-29-2017, 04:28 PM Thread Starter
These are the guys I ordered from, they called me to tell me that the damper 1747 is on back order with no eta because Kawasaki is not manufacturing them anymore. I had to cancel my order.
post #4 of 7 (permalink) Old 07-29-2017, 05:45 PM
Order from eBay using the Kawasaki pn's
Usually they show how many in stock. Also Amazon vendors that are fulfilled by Amazon will have accurate qty on hand
michiganteddybear is offline
post #5 of 7 (permalink) Old 07-29-2017, 10:33 PM
I called Partzilla too about 1747 Damper and it's just as Matthew says. National Backorder with no ETA for fulfillment. Only good news is the part was not marked as "obsolete" so there's at least a chance Kawasaki will make more. Still, we cannot be certain of "if" and "when" Kawasaki will produce more 1747 Damper's. As of now, at least "some" 1748's are still available through dealer networks.
I ordered a full set of 1747 / 1748 dampers several months ago just to have them on hand for when the stator and or damper's fail (which ever lets go first). Seems this was a wiser move than I originally thought! Will try and place a call to Corporate Kawasaki Monday and see if I cant get more definitive information on the fate of the dampers.
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Iceshot is offline
post #6 of 7 (permalink) Old 07-29-2017, 10:56 PM
Fired off a Email and Facebook message to Corporate Kawasaki. Will let you know what I hear regarding the fate of future availability on the 1747 / 1748 dampers.
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Iceshot is offline
post #7 of 7 (permalink) Old 07-31-2017, 04:46 PM
Got some answers from Kawasaki, started a new thread with the information I was given... (link below)
https://www.vn750.com/forum/11-vn750-...ml#post1205313
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Iceshot is offline
