Gas tank dampers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-04-2015, 09:10 PM Thread Starter
Gas tank dampers
Anyone got some?
Nodraws is offline
post #2 of 5 (permalink) Old 05-05-2015, 06:50 AM
rsavant's Avatar
I made one from a motor mount for a"tri five" (55, 56, 57) Chevy small block. The mount only cost a few bucks and I used a Dremel tool to cut it down to fit. I used a razor knife to remove the excess material first. It's basically a rubber puck with a hole through the middle and available at most parts stores.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #3 of 5 (permalink) Old 05-05-2015, 08:12 AM
You could go to the auto parts store and get a sway bar bushing prolly, and just cut them to fit.
post #4 of 5 (permalink) Old 05-05-2015, 09:15 AM Thread Starter
I have the one for the rear.i need the ones for the front will the sway bar bushings work for the front ones?
Nodraws is offline
post #5 of 5 (permalink) Old 05-12-2015, 09:57 AM
heaney750's Avatar
yes they will u just have to shave them to fit
heaney750 is offline
