Brake Lever Bolt - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-11-2014, 08:57 AM Thread Starter
Brake Lever Bolt
Hey guys, Looks like the threaded end of my brake lever bolt (part#92001-1512) had partially sheared at some point. I went to check out why there was so much play in the lever and the threaded end came off in my hand. I have a standard M6 bolt and spacer washer doing the job currently, but I'm looking for a replacement. Ron Ayers has them for $5 w/$8 shipping. I wanted to see if anyone had one lying around before I jumped onto that. Any part out bikes out there that have one lying around?
Doc
ipreventdeath is offline
post #2 of 7 (permalink) Old 07-11-2014, 09:27 AM
JM2001's Avatar
Are you sure? Is it 92002-1201? Just a 8x25 cap bolt. My Ace Hardware has them, about $2.40
http://www.cyclepartsnation.com/oemp...al-torque-link
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 7 (permalink) Old 07-11-2014, 10:22 AM
Ndr
a standard bolt from the hardware store should hold up just fine. No need to get the part specific bolt from the list. A bolt is a bolt, is a bolt. (with the exception maybe of the hardness of the bolt itself)
If you can find one, get a class 8 bolt as it will be stronger then the standard 20 cent bolts. However, I don't believe that it is necessary to get the super strong bolts for that pedal.
Ndr is offline
post #4 of 7 (permalink) Old 07-11-2014, 08:46 PM Thread Starter
No, it's for the handlebar lever, not the pedal. It seems to be a specific design where half has been machined down to an M6 bolt spec while the top half is a wider pin for movement of the lever.
post #5 of 7 (permalink) Old 07-11-2014, 08:48 PM
Sounds like a shoulder bolt
michiganteddybear is offline
post #6 of 7 (permalink) Old 07-11-2014, 08:48 PM Thread Starter
I figured the bolt and spacer washer I used would work, however durability with the spacer washer was more if my concern since it would be experiencing most of the friction. I'll keep an eye on it. Meanwhile I'll look for a cheaper price or find one locally.
post #7 of 7 (permalink) Old 07-11-2014, 08:50 PM Thread Starter
Definitely is. Maybe I can find one from shoulder-bolts.com, haha.
