Need R/R plug - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-01-2013, 09:48 PM Thread Starter
I.T. Analyst, Alpha Geek
FieroGT42's Avatar
Need R/R plug
Idjit kid who had this bike said the wiring was all good. Turns out the R/R plug has been eaten by acid and one pin is scorched looking. I need a new plug without replacing my whole harness. Thanks.
"Fiamma" - 86 Pontiac Fiero GT fastback
Frame-off resto w/ Cobalt SS F23 trans swap, high lift valves, sprint headers, de-cat etc.
Track ready adjustable suspension w/ poly bushings & Herb Adams antisway bars
Too much other stuff to list. 100% built with my own two hands.
94/86 VN750s - Ears shaved, coastered, jetted, R/R moved.
FieroGT42 is offline
post #2 of 9 (permalink) Old 10-02-2013, 04:50 PM
post #3 of 9 (permalink) Old 10-03-2013, 09:43 PM Thread Starter
FieroGT42's Avatar
And 11 something shipping, wow. Is this the same plug?
http://www.ebay.com/itm/161094204858
post #4 of 9 (permalink) Old 10-04-2013, 12:56 AM
it doesn't look right. th eone I posted a link to is definantly the right one... but for the price of the one on ebay, I would give it a shot, and if it doesn't work then get the one from Electrosport.
post #5 of 9 (permalink) Old 10-05-2013, 05:56 PM
blackomen's Avatar
Or just solder it...
Silvia
MCCT's
Rick's stator
Heated grips
Accessory socket on handlebars
voltmeter
dark side nexen SB802 165/80R15
lubed splines
Tuxedo mod
900 seat
Dyna glide rear shocks
blackomen is offline
post #6 of 9 (permalink) Old 10-05-2013, 07:51 PM
you can't solder plastic... the problem with these R/r connectors is they are right under the battery box where battery acid starts taking its toll on the plastic, then the heat of the Goat Belly starts making the brittle plastic even more brittle. Over time the heat and acid destroys the connector. I tried soldering 1/4" spades and hooking hem in with out a connector, filled the inside of my R/R up with silicone, then taped the heck out of it with electrical tape, then plastic dipped the whole thing to make a water tight seal around the connections. but even with all that work, I didn't have as good of a connection as I did when I got the correct plug. (which I stilled soldered the terminals onto the wires).
post #7 of 9 (permalink) Old 10-07-2013, 05:32 PM Thread Starter
FieroGT42's Avatar
I ordered both. They're the same. Both the eBay and that Electrosport part fit, but the clip is on the wrong side of both so it only slides on. It doesn't clip in securely. I may just rig something up to hold it.
Still looking for a good plug if someone has a junk harness, or a connector with the correct clip. Thanks.
post #8 of 9 (permalink) Old 10-07-2013, 06:01 PM Thread Starter
FieroGT42's Avatar
I'm "modifying" the end that would go on the R/R and should be unused. I'm takign off the rear section that woudl be inside the R/R if this plug was installed, and cutting away the protruding plastic from the R/R/ clip so that this new one slides over the pins.
The pins hold it firmly, but I'm gluing it as well. Then I can use the nwe plug on my harness by popping the pins out of the old plug and sliding them into the new one.
The plug will fit and snap shut securly, and I only have to remove/crimp one lead that was burn anyway.
I'll post pictures if anyone wants to see exactly what I'm doing. Never underestimate the ingenuity of a poor man who wants to ride.
post #9 of 9 (permalink) Old 10-07-2013, 09:33 PM
Idjit
heh...brings back memories...my ex GF used to use that term a lot....(damn, I miss her)....
My plug was kinda "melted" too...I pulled it off, reset all the connectors to proper depth, then coated those worn/melted spots on the outside with JB Weld....been fine since....gotta be 8k miles ago now....
