Vulcan 750 tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-24-2013, 09:47 AM Thread Starter
Vulcan 750 tank
Looking for a tank. Picked up a 1990 750 with less then 9,000 miles. Well thank has a pinhole in the bottom and inside its rusty. So I'm looking for a new tank or a way to use this one. I've heard you can acid wash them and then seal them. Anyone know how or want to sell me a tank that's not gonna break the bank?
post #2 of 8 (permalink) Old 07-24-2013, 09:57 AM
HardRock's Avatar
Send Wolfie a PM he had a tank that he was selling.
HardRock is offline
post #3 of 8 (permalink) Old 07-24-2013, 10:56 AM
I.T. Analyst, Alpha Geek
FieroGT42's Avatar
"Acid wash" I'm assuming is phosphoric, same stuff as in ospho, rust-mort, naval jelly, or any other rust killer. Cheapest I've found is $12 + tax at the hardware store with this label:
I've checked the MSDS and it's the same as ospho. It works by dissolving the iron oxide to a softer iron phosphate which inhibits further rusting, without eating the metal.
Hopefully you find one cheap enough to avoid messing with anything.
Edit: Make sure the MSDS says phosphoric acid, not hydrochloric or "muriatic".
FieroGT42 is offline
post #4 of 8 (permalink) Old 07-24-2013, 11:55 AM
HardRock's Avatar
An acid wash can create more problems with a pin holed tank because the acid will disolve the rust and can create more pinholes.
http://www.kreem.com/fueltankliner.html
This stuff can work pretty well to seal the tank after a acid wash, but if there are to many pinholes or they are to big it won't do anything but cost money. They also have a cleaner and etcher, acid wash, that is formulated to prep the surface for the Kreem.
HardRock is offline
post #5 of 8 (permalink) Old 07-25-2013, 12:17 AM
Ndr
This thread: Rusty Tank Cleaning worked wonders on my tank.
However, afterwards, you'll still have the pinholes to deal with.
I've never had to do it, but the general idea of it is to heat the tank (with a propane plumbers torch??) and a small chunk of lead so that the lead melts and flows into the pinholes and then cool sealing the hole.
You're going to want to be absolutely sure there are no gas fumes left in the tank when doing this. Also, this needs to be done on clean bare metal for the lead to adhere properly. So, if there are any pinholes in a visible area, this would mean repainting as well.
If the pinhole under your tank is the only one after the acid wash, at least you could get away with a few coats of Rustoleum to cover up the metal.
Ndr is offline
post #6 of 8 (permalink) Old 07-25-2013, 06:23 AM
jeankawa's Avatar
hi, I have a tank, burgundy colour, from a 1986, no rust, proper functioning
jeankawa is offline
post #7 of 8 (permalink) Old 07-26-2013, 12:12 AM Thread Starter
Wrote to you but no reply yet.
post #8 of 8 (permalink) Old 07-26-2013, 07:21 AM
jeankawa's Avatar
some pics
here they are
ID:	9553   Click image for larger version
jeankawa is offline
