Looking for LOW seat - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-21-2013, 10:02 PM Thread Starter
I.T. Analyst, Alpha Geek
FieroGT42's Avatar
I'm looking for a low profile, narrower seat. I have an 86 VN750 and the stock seat is too wide. It cuts off the circulation in my legs, and I'd rather sit a lot lower. Can't afford a Corbin or anything. Used would be fine. I don't mind doing some minor modifications like for the Mean Streak seat, but I don't have a welder. Thanks
Jason
FieroGT42 is offline
post #2 of 8 (permalink) Old 07-21-2013, 11:29 PM
You could modify your own seat. Strip the foam out from inside and line with thin layers of memory foam and recover. The seat pan isn't that wide, it's the stupid couch padding Kaw used that makes it wide. I had a corbin on my 750 and it was narrower, but not much. Corbin uses a thinner padding material and it made for a better ride, imo.
Just a thought anyways. If you mess up the pan, shouldn't be too hard to find a used stock seat on ebay for cheap.
post #3 of 8 (permalink) Old 07-22-2013, 01:22 AM Thread Starter
FieroGT42's Avatar
Thanks. I'd do that if I could, but I don't have material or any experience with that kind of stuff, or a staple gun that will go through the plastic seat pan. Or the time to do it haha. Too many projects to finish already.
post #4 of 8 (permalink) Old 07-22-2013, 01:29 AM
Got an upholstery shop nearby? Tell them what you want. It'd still be cheaper than buying a Corbin. I had contemplated recovering my stock seat before buying the Corbin. I was going to recover in leather and use the existing staple holes in the pan to run the stitch.
post #5 of 8 (permalink) Old 07-22-2013, 08:32 AM
R/R = Relocated Redneck
Jakzen's Avatar
You don't need a welder to swap for a mean streak seat and it will be lower, but it is a wider seat as well.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #6 of 8 (permalink) Old 07-24-2013, 10:42 AM
2FAS4U
I have these folks do all of my custom seats. Probably in the $140 range with shipping.
http://www.meancitycycles.com/
2fas4u is offline
post #7 of 8 (permalink) Old 07-27-2013, 12:15 AM Thread Starter
FieroGT42's Avatar
I might bit the bullet and chop my seat up myself, just get the foam to fit right, then have someone like them cover it in gator. Thanks.
post #8 of 8 (permalink) Old 07-27-2013, 01:17 AM
SlowBox's Avatar
I did mine myself. I posted pictures of it in other threads. Electric kitchen knives work great on the foam and I found my material at the local fabric store.
SlowBox is offline
