Need Rubber Tank Mount Grommets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-30-2013, 11:09 PM Thread Starter
Chasin' the blacktop
Spencer1's Avatar
Lost one of the rubber grommets that fit between the tank and frame, I'll take both if you have 2. I always seem to be losing these grommets when I try remounting my tank so having a spare would be a good idea.
Spencer
706-207-1080
North Georgia
Spencer1 is offline
post #2 of 10 (permalink) Old 05-01-2013, 06:18 AM
Check down between the ear and frame, that's where I found one of mine. Also found an exhaust nut behind the plate on one foot peg, so you could check there.
post #3 of 10 (permalink) Old 05-01-2013, 10:43 AM
Captive New Yorker....
peterherrm's Avatar
I learned the hard way after dropping those damn grommets a bunch of times to put the tank down first where it goes, then slide the grommets in place....
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #4 of 10 (permalink) Old 05-01-2013, 11:34 AM
romeobravo172
romeobravo172's Avatar
Is funny how you can drop one of those things, right at your feet and cannot find it! They can fall in the darkest places. I actually found one of mine down inside the fan blade housing.
romeobravo172 is offline
post #5 of 10 (permalink) Old 05-01-2013, 02:04 PM
could the rubber pieces be replaced with aluminium instead? Will the tank just vibrate when attached with solid mount or will it fall apart?
92 Stealth
89 Trans Am
67 Camaro
91 suburban v2500
yevgenievich is offline
post #6 of 10 (permalink) Old 05-01-2013, 03:11 PM
Shop owner told me it could vibrate and strip threads on the bolt or hole if it was bolted down tight.
post #7 of 10 (permalink) Old 05-03-2013, 07:01 PM Thread Starter
Spencer1's Avatar
Yea, I looked all around the radiator and even turned the fan incase it was sitting on one of the blades. At this point I've given up looking. Anybody got one or two to sell. Currently I'm running the bike with one missing but I don't like doing it.
North Georgia
Spencer1 is offline
post #8 of 10 (permalink) Old 05-03-2013, 07:05 PM
Just a regular guy
Chris32250's Avatar
I lost one of mine for a while and wrapped the bolt in duct tape...
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #9 of 10 (permalink) Old 05-04-2013, 11:18 PM
I punched out three pieces from 3/8th rubber sheet for mine. Looks like they will work.
92 Stealth
89 Trans Am
67 Camaro
91 suburban v2500
post #10 of 10 (permalink) Old 05-06-2013, 02:13 PM
rubber tape......that and duct tape are the two most commonly used items in my toolbox....just sayin
