LED turn signal boards - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 41 (permalink) Old 02-10-2013, 11:15 AM Thread Starter
Since I never really started a thread solely for these...here it is!
The LED boards:
Standard front turn signal/running inserts are AMBER super blight LED's.
inner ring of 24 LED's set to half brightness (running light)
outer ring of 24 LED's set to full brightness (blinker)
plug and play with pigtailed 1157 base for stock FRONT blinker housing
Rear turn signal inserts:
option 1 - Standard rear: full amber LED board for blinker only. pigtailed with 1147 base for stock REAR blinker housing.
option 2 - turning signal/running light
inner ring of 24 RED LED's set to half brightness (running light)
outer ring of 24 AMBER LED's set to full brightness (blinker)
plug and play with pigtailed 1157 base for stock FRONT blinker housing using a clear or red lens mounted in back.
option 3 - same as option 2 but no connector. this allows you to wire in to your own harness. I can also include a 1147 connector and leave the 3rd wire loose so you can run it wherever you want to tie into the running lights.
You will need to replace your flasher module with a standard EP34 from any auto store to correct the flash blink that LED's will cause because the stock relay is a thermal unit and the lower current draw will cause it to flash as if a bulb is out.
EDIT: adding a link to lenses from Custom Dynamics: Item:RTSL-1300
PM if interested. asking $45/set
album link:
my home made LED boards
__________________
post #2 of 41 (permalink) Old 03-13-2013, 09:48 AM Thread Starter
bump...PM me if you want a set or two $45.00/set shipped.
post #3 of 41 (permalink) Old 03-13-2013, 10:05 AM
I am pleased to say i bought a set of the rear boards from KC and will be the first to say I had looked at others on the web and really didn't like any of them that well.
Some have holes in the center for your stock bulbs to shine through and most of the ones I looked at required gluing the leds to your stock lens.KC's design is a simple board that fits in place of the stock bulbs and the lens and the two screws hold them in place.
I have been very satisfied with them and would recommend them to anyone.Add to that the fact that KC answered all questions I had promptly before I even ordered the led kit.He was more than fair with me and makes a good kit.and the appear to be well made and quite durable as well.I highly recommend them.Thanks KC
post #4 of 41 (permalink) Old 03-13-2013, 02:31 PM
well, depending on finances this payday, I *may* be in for a set. If you get a pm from me this weekend, we both will know!
post #5 of 41 (permalink) Old 03-22-2013, 11:17 AM Thread Starter
post #6 of 41 (permalink) Old 03-22-2013, 11:44 AM
I might have missed this but want to make sure I understand something - so forgive me if it's redundant
For the rear set - if wanting the option for running light and turn-signal - is there anything that has to be done to make that work? Or is it plug and play as well?
Thanks
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #7 of 41 (permalink) Old 03-22-2013, 03:49 PM
bow_dude's Avatar
Send a message via Yahoo to bow_dude
Thanks
i believe that is mostly for front use , but if u wanted to u could run an extra power wire from front running lights to the rear for same effect
little red bewitch
96 750 vulcanlittle red bewitch
12561 miles
r/r relocated
leathersaddle bags(take on/ off)
memphis slim windshield (depends on mood)
p/u coils set at .020
agm battery , flame embossed seat cover
drilled clutch hub(3-20-12)
stainless steel coasters (3-28-12)
toc mccts installed(4/3/13)also changed to led bulbs in tail lamp
k&n air filters (4/20/13)
iridium plugs(4/20/13) along with ngk plug caps
V&H pipes, crash bars , luggage rack 4/5/2014
bow_dude is offline
post #8 of 41 (permalink) Old 03-22-2013, 03:58 PM
romeobravo172
romeobravo172's Avatar
Hay Bow, actually no need to run a wire all the way from the front, can branch off the running or on full time lights already at the rear. (tag & red tail light )
romeobravo172 is offline
post #9 of 41 (permalink) Old 03-22-2013, 04:33 PM Thread Starter
All the connections you need are under the seat.
PM me if you need more details.
Look at my albums...I have the running lights on mine.
post #10 of 41 (permalink) Old 03-22-2013, 08:26 PM
bow_dude's Avatar
yep ur right , can branch off there , sorry small brain f**t on my part
maybe i should go read liberty pilot's thread on common sense lol
little red bewitch
12561 miles
r/r relocated
bow_dude is offline
