Wanted: One connector pin for Shindegen R/R - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-16-2012, 10:35 AM Thread Starter
Crap, I WAS in 5th gear.
I wired into my stock harness, which was a mistake, of course. I need one more pin to wire the R/R directly to the battery. The MOSFET R/Rs come withe one extra pin, so if any of you guys didn't jack up your install like I did, you should have an extra pin laying around. Somebody help a brother out?
Kelly2001 is offline
post #2 of 8 (permalink) Old 10-16-2012, 10:57 AM
JM2001's Avatar
Don't understand what you're looking for. I wired my Mosfet directly to the battery with no special connections.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 8 (permalink) Old 10-16-2012, 11:16 AM Thread Starter
I need a female crimp connector that snaps into the connector housing(s) of the R/R harness. If I could figure out the type of connector, I could order it from Newark or Digikey.
post #4 of 8 (permalink) Old 10-16-2012, 11:27 AM
JM2001's Avatar
Very easy. Go to Auto Zone or Advance Auto and get a 16-14 guage 1/4" female crimp connecter ( they come 5 in a box ). I got the waterproof ones. They also have them in standard or high temp. They fit very tight.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 8 (permalink) Old 10-16-2012, 02:11 PM
Cheman's Avatar
radio shack should also stock the pins. I will look when I get home, I may have one or two laying around. I will let you know if I do.
Cheman
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
post #6 of 8 (permalink) Old 10-16-2012, 04:13 PM Thread Starter
Cheman
Thanks guys. I do have lots of connectors, but none that are designed for the housing. I would prefer to use the exact pin that has the correct retaining mechanism to the housing.
post #7 of 8 (permalink) Old 10-16-2012, 08:13 PM
Cheman's Avatar
Kelly2001, I found one female pin that I think might be from my mosfet mod on my VTX. I not sure if thats what its from. If you want it , PM me your snail mail and I'll send it to ya. If its not the right one, well, add it to your collection
Che
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
post #8 of 8 (permalink) Old 10-18-2012, 12:53 AM
a picture is worth a thousand words
