basket case anyone?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 08-11-2012, 01:22 AM Thread Starter
knees in the breeze!!!
Tofer76's Avatar
http://www.ebay.co.uk/itm/1988-KAWAS...item2a216052f4
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #2 of 16 (permalink) Old 08-11-2012, 11:54 AM
How much it cost to ship it here from the UK ?? And do to the lack of emissions crap, can you?
And how much is 202 pounds in US dollars?
You can buy trash here ya know......
post #3 of 16 (permalink) Old 08-11-2012, 02:10 PM
Bronson's Avatar
Looks like you'll have a blast with that. When do you think you will have delivery?
Bronson
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #4 of 16 (permalink) Old 08-11-2012, 04:09 PM
100% Black & White
Gypsy Wolf's Avatar
about $300 at current exchange rate.... I think he would have to pay me to take it away personally! It's got money pit written all over it...lol
1982 Honda H100A
1990 Yamaha FZR1000R
VROC#35051
Gypsy Wolf is offline
post #5 of 16 (permalink) Old 08-11-2012, 04:27 PM
its a great idea for when we get so old we cant hold the bike up anymore but it might be about the same price to do the same mod to our bike
post #6 of 16 (permalink) Old 08-11-2012, 06:50 PM
Definitely. The funny thing is it's probably just the tensioners making that noise. How many times have we seen a spring change not fix the issue?
I think the chains stretch a bit, and go beyond the ability of the ACCT to hold them at bay, so even with a spring change it can't cope. MCCT keeps that constant pressure, and hopefully, keeps the chain happy and not-streching.
post #7 of 16 (permalink) Old 08-11-2012, 09:33 PM
If it wasnt in the UK, I'd try to grab it in a hearbeat...was just talking to KC and Merc about getting a basket case and making a trike (VN is set up fer it since the driveshaft)...and its a 700, and thats what I got...so know em well...this'd be a perfect winter project for me !!! Damn shipping !
post #8 of 16 (permalink) Old 08-11-2012, 10:08 PM
More I think about it...more I wanna do a trike project....was a Yammy (I think) wreck at the junkyard when me and KC went...V-twin, guessing 750-1000 with driveshaft....stick a rear from a GM J-car in and done...lil steel and a Mig welder...man...cant wait till 2013 when I get my small pension !
First project is a welder, then a basket case, then a trip to the Doc's...I really miss building bikes !...
post #9 of 16 (permalink) Old 08-12-2012, 12:14 AM
I have a spare ACCT that I have converted to MCCT. The total adjustment possible extends the mushroom headed tensioner bolt out about 1/2 or 9/16 of an inch. If the new TOC springs won`t apply sufficient pressure to tighten the cam chains, go to MCCTs.
There are several threads outlining converting the stock ACCT body to an MCCT. The biggest objection to modifying a Kawi`s aluminum bodied ACCT seems to be the fear of the small threads at the top of the tower stripping out due to the relative softness/weakness of aluminum compared to TOC Manufacturing`s steel units. I overcame this possible weakness by using an idea gleaned from one of Wolfie`s posts. He suggested epoxying a 6 mm nut up inside the top of the tower for the adjustment screw to thrust against.
Hallelujah, the nut fits up there! The condition of the aluminum threads that held the little sealing cap screw is now irrelevant. The aluminum threads can even be drilled out if desired, as the nut will take all the thrust from the adjustment screw.
I got all the parts I needed for a buck.
1- M6 X 1.0 X 90mm long cap screw (bolt), which took about 5 minutes to run through a die to thread full length.
2- rubber/steel bonded sealing washers of slightly different diameters.
The larger one sitting against the ACCT body (and is equal to or slightly larger than the OD of the tensioner body) but the ID hole is too big to seal properly, so a second smaller washer with an ID that seals against the adjustment screw is placed on top.
2- plain 6 mm nuts to lock the adjustment screw.
Looking back I could have used just one (1) lock nut in their place.
I had 3 of the 6 mm flanged nuts that had held the licence plate mounting bracket and illumination lamp to the fender before moving the plate up directly under the taillight so it didn`t look and act like a mudflap.
I used one of those flanged nuts to epoxy up inside the ACCT body.
Probably no better or worse than using a plain 6mm nut but I used it just because I had one. <shrug>
I have not installed it yet, but have it mainly as a spare when needed.
Or I may install it on the front cylinder now as an experiment to see how well it works, and how well it stands up in the long run.
post #10 of 16 (permalink) Old 08-12-2012, 05:33 PM
Awesome, brother !!!! ...ya use what ya gots !!!!
..."specs" ?...whats specs ?????...and if ya aint got it, ya make it !!!
