Engine Gaurd In Great Shape!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 06-12-2012, 03:18 PM Thread Starter
MaDeInSin's Avatar
Very minor scuffs and mild pitting... I think it looks GREAT all in all.
Last one of these I saw sell on Ebay a couple of weeks ago went for exactly
$152.50
+ $18.33
shipping
I am selling this one for 150 shipped.
I had a buddy ask me about this a couple of weeks ago so he will get first crack at it.
Otherwise.. First buyer with the cash gets it.. Ill put it on ebay later this week if I have no bites.
Thanks!
ID:	4607   Click image for larger version
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #2 of 22 (permalink) Old 06-12-2012, 03:24 PM
Member? ... check.
ZCraggRatt's Avatar
Hey MaDeInSin,
Not a buyer, but it would be great if you could get a dimension from the right side bracket, the one that is not welded. I need to get the dimension from hole center to hole center.
Help a brother out would ya' ?
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #3 of 22 (permalink) Old 06-12-2012, 03:38 PM Thread Starter
MaDeInSin's Avatar
Sooooo just to make sure I am giving you the correct info...You need on the right side... from the center of the top hole... to the center of the bottom hole? If that is true then the answer is 4 3/4 inches.
Attached is the picture of how I measured it.
Let me know if this is what you needed!
Accomplishments;
Iridium Plugs
Lubed the Spline
Re-Jetted
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
post #4 of 22 (permalink) Old 06-12-2012, 03:40 PM Thread Starter
MaDeInSin's Avatar
ooooooo and after all that work.. I think that is not what you wanted.. I see the other side support is bolted on... That bracket is 3 inches from center hole to center hole...
Accomplishments;
Iridium Plugs
Lubed the Spline
Re-Jetted
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
post #5 of 22 (permalink) Old 06-12-2012, 04:06 PM
Member? ... check.
ZCraggRatt's Avatar
Thank you friend. That ought to be close enough.
~~C8>
post #6 of 22 (permalink) Old 06-12-2012, 07:29 PM
Member? ... check.
ZCraggRatt's Avatar
You know what, on second thought, I should probably be more clear just to be sure.
I was looking for a hole center to center on just the bracket itself. Not from bracket to guard. Like, if you took the bracket off the guard, hole to hole of just the bracket.
Is that what measured three inches?
~~C8>
post #7 of 22 (permalink) Old 06-12-2012, 07:47 PM
romeobravo172
romeobravo172's Avatar
That flat bolt on bar or plate is about 4 inches long, hole to hole is about 3-1/2, is really hard to measure on bike! Sounds like that plate did not come with guard? That one to me would be the last one to bolt on, so you would have some wiggle room to play with. I cheated a little when I installed that piece, took that plate and where the frame bolt has to be backed out, ( also have to loosen exuast, did not have crush gasket to replace it with ), took a metal cutting wheel and cut out a notch to just drop over that bolt. Made install a breese!
romeobravo172 is offline
post #8 of 22 (permalink) Old 06-12-2012, 10:54 PM
Member? ... check.
ZCraggRatt's Avatar
Thanks for the reply romeobravo.
I bought a guard that had no hardware. I have to make that bracket. I do have mounting instructions that designate the bolt sizes, so I can cut the right size holes, I just didn't know how far apart they are suppose to be.
Cutting a slot in the hole to "drop over" is a great idea, but I thought the bolt would be too short. I'm gonna' try that.
Thanks again, great tip.
~~C8>
post #9 of 22 (permalink) Old 06-12-2012, 11:56 PM
romeobravo172
That bolt in the frame is plenty long! You are going to have to make a couple shims!! You do know that right? Will have to look but am sure there is at least 2, basically the same thickness as that plate. Both foot pegs need the shims on rear bolts.
post #10 of 22 (permalink) Old 06-12-2012, 11:58 PM
Member? ... check.
ZCraggRatt's Avatar
Yea, I got the shims covered. Actually, I plan on using a couple of thick washers on each side. The only piece I'm missing now is the right side bracket.
~~C8>
~~C8> Ratt
Next: LED's
