Wanted VN750 discs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 03-11-2012, 05:24 PM Thread Starter
Wanted VN750 discs
Just bought an 86 VN750 with knackered discs. Do any other models discs fit the 86 model and has anybody got any for sale???
megawatt is offline
post #2 of 11 (permalink) Old 03-11-2012, 05:40 PM
rev it up's Avatar
Hi,,there is some on Ebay !!. They are in co.cork,Ireland. Ebay No..280713427168. Price 50 plus 10 p&p. Take a look,,see what you think. Good luck.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #3 of 11 (permalink) Old 03-11-2012, 06:00 PM Thread Starter
Cheers mate, need to find out how much skimming they will need, look similar to mine???
megawatt is offline
post #4 of 11 (permalink) Old 03-11-2012, 06:10 PM
rev it up's Avatar
All the vn750 discs will fit 1986-2006 !. Not sure you can skim them though. Hope someone corrects me if im wrong !.
VN 750 A8 1992.
27000 miles.
to UK in 1996.
New for 2012.
Iridium plugs.
brake pads(Kyoto)
post #5 of 11 (permalink) Old 03-11-2012, 06:37 PM
Front brake rotors new thickness specs are 4.8-5.1 mm, (0.189-0.200")
Wear limit is 4.5mm, (0.180")
If your discs are badly worn or grooved already, there is not enough metal left to have them machined flat again without going under the wear limit.
post #6 of 11 (permalink) Old 03-11-2012, 06:42 PM Thread Starter
Cheers mate, so if I buy second hand discs with wear grooves in, I need to know the thickness at the tops and bottoms of the grooves, not easy?
megawatt is offline
post #7 of 11 (permalink) Old 03-11-2012, 07:25 PM
Before buying any used rotors either measure them yourself with a micrometer, or if buying off Ebay have the seller measure them for you.
At the best there is only 0.020" (20/1,000") between new and the wear limit for the rotors.
They really are not meant to ever be machined back to a usable condition.
Note that one member, VN750 Rider/Jerry, has modified his front brakes by removing one rotor and the accompanying caliper and hose.
He claims no less braking power with only one rotor. I`m not defending or attacking his modification, as it works for him.
You may want to consider going that route too, even if only temporarily, if you can locate only one good rotor on Ebay in the near future.
post #8 of 11 (permalink) Old 03-11-2012, 07:37 PM Thread Starter
There aren't many available over here and postage charges are expensive. Gonna measure my discs and try to find similar discs that will fit off another bike. Can't afford new ones.
megawatt is offline
post #9 of 11 (permalink) Old 03-11-2012, 08:32 PM
rev it up's Avatar
Have a look at an old thread i submitted on here !,,type in the search option [Alien brake discs]. I had the same problem,but i managed to make the discs a lot more presentable by using a sanding disc on them,,manualy,,not on a machine or power tool. It worked for me !!.
VN 750 A8 1992.
27000 miles.
to UK in 1996.
New for 2012.
Iridium plugs.
brake pads(Kyoto)
post #10 of 11 (permalink) Old 03-11-2012, 10:01 PM
Here`s the link: https://www.vn750.com/forum/showthread.php?t=20569
