04 VN 750 Lower End Parts Needed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-11-2011, 09:13 PM Thread Starter
I'm in need of the balance shaft and everything attached to it on the left side of the engine. I also need a new flywheel as those teeth are ground down. In need of the left cover as well and maybe the left engine case if they cannot weld the web back on. I know its a lot of work to get this bike back in shape but I have a long winter ahead to play. Looking for someone that had these parts and hopefully reasonable. Any help would be appreciated. Thanks, Brandon
bmroy is offline
post #2 of 7 (permalink) Old 10-13-2011, 05:11 PM
Hi
Check Ebay. there was a balance shaft on there not long ago. Did your dampers sh*t the bed?
If the left case can't be fixed you will need to find a matched pair of cases, they can't be mixed and matched.
skrapper is offline
post #3 of 7 (permalink) Old 10-13-2011, 07:51 PM
As I pm'd before I have a flywheel if you need it. I'll send the pics if your interested.
post #4 of 7 (permalink) Old 10-14-2011, 10:25 AM
Hi,
There is a balance on Ebay and it ends today. Look in vn750 other it's listed as chian/ sprocket
skrapper is offline
post #5 of 7 (permalink) Old 10-14-2011, 10:37 PM Thread Starter
I dont think the dampers are an issue. But the end of the shaft got all bugered up when the bolt came out and the gear tried to come through the case.
bmroy is offline
post #6 of 7 (permalink) Old 10-14-2011, 10:45 PM Thread Starter
Thank you for the info on the case. I had no idea they needed to be a matched set.
bmroy is offline
post #7 of 7 (permalink) Old 10-19-2011, 09:29 PM
I sent you a PM.
