Need an ignition hockey puck/switch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-10-2011, 09:52 PM Thread Starter
Ceal's Avatar
I'm wondering what I should expect to pay for an ignition hockey puck or switch with the hockey puck attached, and if maybe someone here has one available.
Didn't see any on ebay and I probably can't afford a new one.
One of the tabs on mine is broken and it causes a false contact. So I gotta find the "sweet spot" with the key so the bike will start. However, I expect a bump could shake the key and make the bike turn off.
Ceal is offline
post #2 of 10 (permalink) Old 09-11-2011, 02:19 PM Thread Starter
Ceal's Avatar
bump!
Ceal is offline
post #3 of 10 (permalink) Old 09-11-2011, 03:29 PM
pm sent
post #4 of 10 (permalink) Old 09-20-2011, 03:26 AM
I have one in my collection. Let me know if ya still need it.
RakerBill is offline
post #5 of 10 (permalink) Old 09-20-2011, 12:40 PM Thread Starter
Ceal's Avatar
I already received one from Cindy... thanks though!
Ceal is offline
post #6 of 10 (permalink) Old 09-21-2011, 10:54 AM
The Admiral's Avatar
ignition puck
My bike is starting to do something similar to what Ceal was describing. I have to wiggle the key or cycle it off/on(sometimes) to get it to start. Is this puck the doohiggie I need? And if so Raker do you still have the part?
The Admiral
2000vn750
16000 miles and counting
Items done:
Plugs beaded/gapped at .032
Carbs at 3.5 turns
Seafoam tank and crank
Rotella Syn 5W-40
Spline lube
Ovsz Shinko230's
Grambo - cam chains
Pickups gapped at .020
R/R relocate
Sealed Battery
To Do:
Iridium plugs
LED Lighting and 100W Bulb
Acct to Mcct Conv
The Admiral is offline
post #7 of 10 (permalink) Old 09-21-2011, 11:15 AM Thread Starter
Ceal's Avatar
It might be. You could check out yours to make it work or you can just buy another one.
Mine did this same thing when I bought it but I managed to make it work again by taking apart the hockey puck and cleaning all the contacts and stretching out the little springs a bit. When I put it back together and back on the bike it worked great for quite a while (I guess almost a year).
I took it off again because of another problem that I thought might have to do with the same part (and it didn't) and when I did I broke the plastic housing... so that's why I had to look for another.
So you could fix yours, but it's definitely simpler to just swap it out.
In my case, after I bought the one from Cindy I just used super glue on mine to see if I could make it work in the mean time that the newer one got here. It's perfect now. But now if anything goes wrong I can't open it up cause I glued it, so if anything happens I will have the newer one to put in
Ceal is offline
post #8 of 10 (permalink) Old 09-21-2011, 12:08 PM
Crobins365's Avatar
It's easy for road grime to get in there, Admiral, so I'd go ahead and pull it apart as Ceal recommended and clean everything up. I had similar symptoms and cleaning the contacts, making sure the screws for the hockey puck were seated properly, etc. fixed the problem. It's the least expensive way to start, anyway!
C
Crobins365 is offline
post #9 of 10 (permalink) Old 09-22-2011, 01:57 AM
Yes Admiral, I still have it, and it's in excellent shape with the key. I'm not sure what the going price is, so shoot me an offer, and we can go from there. I have paypal, and I will ship it priority with insurance, and I think it will fit in a small box, so shipping will be around $6.00
e-mail is racer_bill at hotmail dot com, so shoot me an e-mail if it's easier.
post #10 of 10 (permalink) Old 09-22-2011, 10:16 AM Thread Starter
Ceal's Avatar
Bit of advice if you do open up yours... Open it over a table and do it as slow as you can. There's 3 springs, a ball bearing and 3 contacts inside that can jump out of there if you're not careful. It happened to me the first time and I had no idea at all what had jumped out lol so I was lucky to find it all again.
Ceal is offline
