Parting out '95 engine - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 09-04-2011, 10:11 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
As some of you may have seen in this thread here, I blew up the front cylinder of my '95 Vulcan. It had just over 42K miles when it gave out. As a result, I'm going to be getting an entire used engine and therefore will be parting out the good parts of this one.
Parts that are known to be no good:
- Right side case (damage to oil line and an internal "shelf")
- Front head (exhaust valves got slammed by the piston, bent and jammed against the head)
- Rear head (there's a hole where the spark plug sleeve goes that was causing an oil leak, was already planning to replace that head before the engine blew)
- Rear exhaust manifold (one of the bolts to connect the exhaust pipe had previously broken off)
- Cams (excessive wear on the teeth of the gears)
- Crank shaft (damaged from when the rod broke)
I had already purchased a used front cylinder, piston, and rod. I got them for a pretty good price, and all I want is my money back on that purchase since I never installed them. Therefore, the cylinder and piston together (from an '01) will be $56.24 + shipping, and the rod **is sold**.
Everything else in the engine should still be good. I have not closely examined all the remaining parts, but a cursory inspection saw no damage.
Parts such as the stator and rear bevel case are not included as yet, as I may need them when I get a used engine. Basically any external parts that may not be included with another engine. If they are not needed, I will update this thread at that time. The stator I plan to keep no matter what since it's only 2 years old.
I'm not going to list the prices for every individual part here, the list would be too long. Instead, I figure to sell everything for 25% of what the price is on bikebandit.com.
So if you want something, let me know either in this thread or through PM. I will then examine the part(s) more closely and let you know if it seems to be good enough to sell, after which I will clean it and ship it. Shipping will either be USPS Priority Mail or UPS, whichever is cheaper. I will keep a running tally in this post of the parts that have already sold.
Have at it!
Parts already sold:
-Side oil drain plug
-2 Connecting rods
-Shift tie rod
DaveT319 is offline
post #2 of 2 (permalink) Old 10-20-2011, 10:47 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
No one needs any engine parts? I'll be putting whatever is good up on eBay soon, wanted to give you all first crack at them.
DaveT319 is offline
