Looking for muffler(s) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-24-2011, 10:20 PM Thread Starter
johnm's Avatar
Hey all,
I pulled my exhaust to prep for other maintenance and found my right muffler -- having previously been broken and welded -- was broken once again. Guess it's time to replace it.
I've been browsing ebay, but thought I'd check here before I make a purchase. I'm interested in...
1) another intact (i.e., baffles not removed, drilled, etc.) oem right side muffler, or
2) exploring possible aftermarket slip-ons. Nothing real loud.
I'm in the process of doing other necessary work on the bike, so anything that is in good condition, in the $50-$70 range (of course, less would be even better), and doesn't require an engineering degree or welding skills to achieve fitment is a definite plus. I will retain the goat's belly, so right/left installation is desired.
Sorry for the long post, but thanks for reading. I'm open to considering a range of possibilities, so let me know what you have.
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #2 of 3 (permalink) Old 08-25-2011, 01:20 PM
dirtrack650's Avatar
If you are on a budget, find some Sporster or Dyna mufflers on ebay. The usually go cheap, look good, and sound great. Make sure the mufflers are not 'punched out' before you bid on them. Several users here like the sound, and the looks.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 3 (permalink) Old 08-25-2011, 03:08 PM Thread Starter
johnm's Avatar
^^^ Actually have been looking at some on ebay, but thought I'd check here. Maybe someone needs room in their garage. Plus, I would trust that most regulars on here wouldn't try to take me for a ride (yep, pun intended).
John
1989 VN750
VROC#31798
johnm is offline
