TOC MCCT's - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-03-2011, 08:14 PM Thread Starter
TOC MCCT's
Hi - wondering if any of you out there might have a set of the TOC MCCT's for a 87 750.
I am getting ready to rebuild the engine, and as the coolant tank does not fit with the home made converted mcct's. just looking to get a set on the cheaper side if possible.
Thanks
Andrew
Andrewr is offline
post #2 of 5 (permalink) Old 08-03-2011, 09:20 PM
If only it had 6th gear..
DavesVulster's Avatar
Did you use 40mm bolts? I read that someone used 30mm Allen's and that's what I bought (haven't done the mod yet). How much clearance do you need?
DavesVulster is offline
post #3 of 5 (permalink) Old 08-05-2011, 07:22 PM
I did my conversion today. I was able to move the coolant bottle up a little bit higher and sit the edge of the bottle on top the 10mm bolt using the lip of the washer to clamp it. That way the mcct bolt ( I did use 30mm length allens ) can sit in the bottle's cut out where the brake cable runs. Seems pretty secure to me and hardly looks any different. The only other thing I can think of is heating up the bottle a little and pushing in the corner that interferes with the bolt. Don't really want to do that so I'm trying this out. Gonna go off roadin' in a bit to test it . Anyway, I figured I'd offer up my findings. Peace,
Dave
post #4 of 5 (permalink) Old 08-06-2011, 12:38 PM
dirtrack650's Avatar
This my acct > mcct. It's working well, no issues.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 5 (permalink) Old 08-06-2011, 01:31 PM
Good idea also. I like it. So many crafty people on this site.
