Need case bolts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-14-2010, 10:36 AM Thread Starter
Need case bolts
As the title says, I need a full set of case bolts, as cheap as possible.
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #2 of 7 (permalink) Old 03-14-2010, 03:31 PM
flitecontrol's Avatar
I may have them mixed in a bag of VN750 bolts and small parts I got from ebay. But I have no idea which bolts go where. If you can find someone who can provide the measurements for the various case bolts, I will go through what I have and let you know. But I'll be out of pocket M-F of this week.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 7 (permalink) Old 03-14-2010, 04:00 PM Thread Starter
If I remeber correctly, the case bolts are the only ones with a hex head, all of the other screws should be philips head.
It will have
degoated, Eared
ported and polished
balanced
Chopperfix
Duck's Garage
Duck is offline
post #4 of 7 (permalink) Old 03-14-2010, 10:36 PM
Search Goddess
Dianna's Avatar
Easiest way is to check the online fiche like
http://fiche.ronayers.com/Index.cfm/...roup/Crankcase
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 7 (permalink) Old 03-14-2010, 10:48 PM
Search Goddess
Dianna's Avatar
Someone did some work and the crankcase bolts are listed as follows (Sorry the columns don't match up well )
Reference Part Number Page Description Screw/Bolt Diameter Pitch/?? Length Qty
130 130P0616 CRANKCASE BOLT-FLANGED Bolt 6 16 1
132 132E0630 CRANKCASE BOLT-FLANGED-SMALL Bolt 6 30 8
132A 92002-1657 CRANKCASE BOLT,6X40 Bolt 6 40 1
132B 132E0660 CRANKCASE BOLT-FLANGED-SMALL Bolt 6 60 3
132C 132G0616 CRANKCASE BOLT-FLANGED-SMALL Bolt 6 16 4
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 7 (permalink) Old 03-14-2010, 10:53 PM
Search Goddess
Dianna's Avatar
If you happen to belong to the yahoo VN750 group the file can be found here
http://autos.groups.yahoo.com/group/...%2C%20Washers/
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #7 of 7 (permalink) Old 03-15-2010, 12:08 PM Thread Starter
Thanks,. thats what I needed to know.
It will have
degoated, Eared
ported and polished
balanced
Chopperfix
Duck's Garage
Duck is offline
