1986 V750 needs a little work - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-10-2009, 08:51 AM Thread Starter
1986 Vulcan 750
I have a 1986 Vulcan 750, 6,600 original miles.
The bike needs some work, as it hasn't been run since 1992.
The original owner road it for a couple of years, enjoyed it, bought a Harley, and parked this one in a barn.
I recently took ownership, and had it shop serviced where the tank was relined, carbs cleaned, and coolant flushed. The shop started the bike, but a top end noise started and they shut it down. They offered to pull the motor and diagnose, but I held back. I intend to try to do this myself, as it sounds like either the HLA need replaced or just bled.
However, I have limited access to shop space and since the acquisition has caused a little domestic disharmony, I wanted to see if anyone is looking for a project.
It will need new tires, but otherwise should be good to go after the top end work. Overall the bike looks OK with some surface rust.
I am asking $1,000, but of course am open to discussion. If there's no interest, I will probably try to tackle it myself.
The bike is located close to Dayton, OH.
jrw32 is offline
post #2 of 4 (permalink) Old 08-10-2009, 01:48 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Sounds like it time to try the Ol' Grambo/Gambo Trick........
Here's some info on it.
https://www.vn750.com/forum/showthread.php?t=1076
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #3 of 4 (permalink) Old 08-10-2009, 01:55 PM
Simple Solutions
seebeeare's Avatar
hla im not sure what that is but try grambos trick and maybe a lil seafoam in the crank case its sat for a long time and i bet its something stuck as oppose to broken like jt sugested grambos trick ....it could have been the coffee grinder too ... see if u can hear it and try and pin point it use a stethascope or a screwdriver... tearin into it is gonna be about 2 bills there is a lot of rubber i would replace if u do decide to tear into it but in the end you will be happy with this bike
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 4 (permalink) Old 08-10-2009, 01:58 PM
On His Lady Vulcan
wkrizan's Avatar
Yup....Grambo trick!!!
Pictures of the "Ladies"
wkrizan is offline
