ISO exhaust heat shields with the screws - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By rerb
post #1 of 5 (permalink) Old 03-14-2020, 02:37 PM Thread Starter
rerb's Avatar
All of the screws and clips on my heat shields are rust fuzed together and wont budge. I cant reattach them to the pipes now. I'm mostly looking for the bikes right side exhaust shield, which is the shorter one that doesn't run up the header (rear cylinder). If you have a good functioning one just laying around I'd love to buy it off you.
rerb is offline
post #2 of 5 (permalink) Old 03-14-2020, 07:16 PM
Not sure what ISO has to do with it. Way back when I replaced the stator on my 2002, the rear tab broke off the rear heat shield. I used a Dremel with a reinforced cutoff wheel to cut a notch out at the bottom rear corner of the shield, then used a hose clamp to attach it to the muffler. It was barely visible. But you can find those parts on eBay. I also had to replace a right rear muffler because the weld cracked at the very front and caused an exhaust leak. I got a really nice one off eBay for $35.
Any metric bolt of the proper size will work just fine, but the shields themselves are bike specific.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 5 (permalink) Old 03-14-2020, 10:02 PM Thread Starter
rerb's Avatar
Doesn't ISO mean "in search of"? If not I'm sorry
And this issue is the clamps and screws are so rusty I can't move them without breaking. I'll try your hose clamp method though, it sounds promising.
OleDirtyDoc likes this.
rerb is offline
post #4 of 5 (permalink) Old 03-15-2020, 12:52 AM
The only ISO I know of refers to the International Organization for Standardization. If nothing is broken yet, you might be able to save the shields by cutting the bolts with a Dremel, and removing the shields and clamps intact. Then you might be able to save the shields. But the one that broke on mine was not even rusty. Just very thin metal and poor quality construction.
1979 Vespa P200E
post #5 of 5 (permalink) Old 03-15-2020, 03:16 AM
Yup
Sent from my 100005206 using Tapatalk
