Vn750 Engine needed in uk - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-27-2018, 01:31 PM Thread Starter
Hi this is a bit of a longshot, but looking to see if anyone has a VN 750 engine for sale and would be willing to ship to the UK.
I have seen one on Ebay but unfortunately the person wasn't willing to ship.
Thanks Andrew
post #2 of 4 (permalink) Old 08-06-2018, 12:18 PM
Hi Andrew.
What state does the engine need to be in? I have one which is partially dismantled, although I have all the parts. It does need a clean up as it's been sitting undercover in the garden for a few months. It's from a 95 year that was running fine. I started to strip it down but never carried it on as I was already doing my current project.
Thanks.
Getting old, but not too old to ride a VN750
Ian J is offline
post #3 of 4 (permalink) Old 08-18-2018, 03:06 AM
Hi Ian, Andrew was asking for me, I've since sourced an engine from Aberdeen. It might be worth me having a look as i found getting one a challenge, having another spare wouldn't hurt!
1) How far did you go with the strip down?
2) Where are you located?
3) How much would you let it go for?
Cheers, Jamie
jamiebont is offline
post #4 of 4 (permalink) Old 08-19-2018, 06:00 AM
JETHRO's Avatar
Hi, If your doing a rebuild don't forget to check out Andrew Roth on youtube , he has about 28 videos on the VN750 (complete rebuild).
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
