Battery Charging - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 02-28-2009, 03:45 PM Thread Starter
Gemguy's Avatar
Question Battery Charging
Sun shinning and about 40 degrees today here in Long Island, NY, had to take it out for a ride. In the 3 or so years that I own her it was the first time she disappointed me. Full choke on she cranked and cranked with no heartbeat until I finally decided it was time to charge the battery and try again later. Did the drill, opened the tool box and undid the screws to take off the seat so I could hook the charger to the battery.
Has anyone rigged a quick disconnect polarized plug somewhere that is easier to access the battery without removing the seat? On my previous Vulcan 500 I had attached a marine 2 pole jack/plug with short wires that I had sitting in behind the triangle cover, right under the seat, on the right side of the bike that I could pull out and plug in a charger. It worked OK but if someone has a better idea I would love to hear it. On the last bike the seat came off with a key lock on the side and this one has to be unscrewed to remove. Neither one is a very simple affair.
If anyone has solved this problem and wants to reply with a couple of pictures it would be appreciated.
Ride safe y'all.
Gemguy is offline
post #2 of 20 (permalink) Old 02-28-2009, 03:51 PM
cm4cm5's Avatar
my battery tender has wires that connect to the battery and run out to behind my side covers. when im ready to charge, ill pull the plug out from the side cover and connect to my charger. i also use this plug for my voltmeter
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #3 of 20 (permalink) Old 02-28-2009, 04:24 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I do the same and it works great. Get a maintenance free battery too.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #4 of 20 (permalink) Old 02-28-2009, 04:26 PM
Not to say its better, but I put a marine cigarette lighter socket (water proof) under my rear luggage rack and can use it for the batt. tender, cell phone, GPS or whatever has the lighter plug in...
post #5 of 20 (permalink) Old 02-28-2009, 04:52 PM
I remember seeing a post somewhere that you could jump start it through the right side cover without removing the seat. Someone should chime in on this if I'm right.
post #6 of 20 (permalink) Old 02-28-2009, 04:56 PM
My tender also came with a short connector that screws into the battery terminals with the battery cables then has a polarized quick disconnect that i have routed right behind the side cover. i dont park anywhere near an outlet but when i finally can do that, itll be way too easy to plug in my tender.
drguitarum2005 is offline
post #7 of 20 (permalink) Old 02-28-2009, 05:08 PM Thread Starter
Gemguy's Avatar
Talking Thanks
Thanks everyone. Basically I did the same thing on my old bike and will have to do it again here. I don't want to buy another charger so I'll find a waterproof polarized plug and socket and mount it under that side cover as before and pull it out when I need it.
I thought there might be a better way but guess not. Thank you all for your input.
Spring is around the corner, get those bikes cleaned up and ready.
Gemguy is offline
post #8 of 20 (permalink) Old 02-28-2009, 05:54 PM
Concert connoisseur
wib714's Avatar
my charger was 29.99 at autozone and has the connector. well worth it!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 20 (permalink) Old 02-28-2009, 05:57 PM
750Doug's Avatar
My plug 9for the charger) that is hard wired to the battery sticks out about an inch between the top of the RH side cover, and the bottom edge of the seat, so it's a simple plug/unplug without any tools or removal of anything.
Tomorrow if I remember, I'll take a picture.
750Doug is offline
post #10 of 20 (permalink) Old 02-28-2009, 07:15 PM
The Professor
lance328's Avatar
You can do this by connecting + jumper cable to the solenoid post from the battery.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
