Random shut down, need some help. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #1 of 29 (permalink) Old 01-22-2018, 04:53 PM Thread Starter
S3rv3nt's Avatar
Running and riding just fine when the bike hiccups and stumbles a little then stops running. Some times it will just bump start itís self while coasting and if not then it will always start right back up with the button. Some trips it runs like a champ and no issues at all. All cables look good and I canít find a problem or duplicate it consistently to track down its cause. Any clues as to the phantom headache that is happening to my 86 750 Bobber? I have done the ear shave and bobbed it but pretty much stock otherwise. It is garaged and I live in AZ so not really a cold or Hot issue since it is random during all weather. I always use premium and use a fuel additive. I am getting spark from all plugs and fluid levels look good also. Iím guessing something with carbs but Iím not sure on carbs too well so before I had my shop tear them apart for me I thought Iíd ask for some help from the real experts on these bikes.
Thx in advance.
S3rv3nt is offline
post #2 of 29 (permalink) Old 01-22-2018, 04:58 PM
look up POOGS(phantom out of gas syndrome) .if ya wouldn't mind,would you please do an introduction for us in the newbie section?and after you get your post count up,how about some pictures of your bike?thanks
post #3 of 29 (permalink) Old 01-22-2018, 05:28 PM Thread Starter
S3rv3nt's Avatar
POOGS was my first thought for issues but I have done the vent clean out and it has not seemed to help. And since it starts right back up I figured it was some other issue. Would changing the petcock to a free flowing version help with fuel flow? Any other guesses as to my problem?
S3rv3nt is offline
post #4 of 29 (permalink) Old 01-22-2018, 08:30 PM
Does the switch ever act funny?
Also check connections under the left neck cover.
Premium isn't helping it any, but it's not causing it to stall. Is probably building up carbon though.
post #5 of 29 (permalink) Old 01-22-2018, 10:03 PM Thread Starter
S3rv3nt's Avatar
Switch replaced
I had suspected a problem in the starter or kill switch so I removed and replaced them. Moved the location to the neck cover on the right side. Then I changed to a whiskey throttle while I was at it. ( cleaned up the look) problem still happening. Today I went back through the vent cleaning process ( just for giggles ) and removed my tank bag. I am having a thought that perhaps the tank bag is choking the fill vent? I will run it a bit and see if it helps, but since it has been random it might be a few days to get a good feeling on a fix.
S3rv3nt is offline
post #6 of 29 (permalink) Old 01-22-2018, 10:28 PM
does it happen when the bars are turned either to the left or right?
post #7 of 29 (permalink) Old 01-22-2018, 10:39 PM
check for loose connections or bare wires under the headlight bucket
post #8 of 29 (permalink) Old 01-23-2018, 07:50 AM Thread Starter
S3rv3nt's Avatar
No issues turning the bars and I will pull all connections on left side neck panel and dielectric grease every thing after work.
S3rv3nt is offline
post #9 of 29 (permalink) Old 01-23-2018, 08:23 AM
ignition switch
the evil seed of all random problems
Paulywog likes this.
michiganteddybear is offline
post #10 of 29 (permalink) Old 01-23-2018, 11:50 AM
Originally Posted by michiganteddybear View Post
ignition switch
Yea, they are a real PITA. I second the ignition switch.
