Driveshaft-Spline Spring-?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 02-09-2009, 08:14 AM Thread Starter
OK-I lubed the rear splines last year when I put a new rear tire on but don't remember any spring...... CRS or whatever I intend to check and make sure the spring did not fall out and roll off into never never land...
So the spring should be in the rear end of the shaft right...
And should I pull the shaft and lube the front, I only did the rear the last time???
post #2 of 14 (permalink) Old 02-09-2009, 12:49 PM
The Professor
lance328's Avatar
The spring goes in the rear. Lube front splines and u-joint.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 14 (permalink) Old 02-09-2009, 01:42 PM Thread Starter
Thanks Lance, thats what I thought, and I guess I really do need to lube the front splines as all I did last year was the rear splines...
Does the shaft just pull out and lube and stick back in...????
post #4 of 14 (permalink) Old 02-09-2009, 01:48 PM
The Professor
lance328's Avatar
Pull the shaft out, slide the boot off of the bevel gear to help install the shaft.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 14 (permalink) Old 02-09-2009, 10:11 PM
HAWK
Ccspinner's Avatar
The front splines are not as important, you can just pull the rubber boot back and spray in some white lithium grease.
If you lubed the rear with good Molly then you should be good for 10,000 miles.
I did mine every other year and it was good when I removed it.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #6 of 14 (permalink) Old 02-09-2009, 11:00 PM
I do mine every other tire, which is about every 3 months.
Chappy is offline
post #7 of 14 (permalink) Old 02-09-2009, 11:33 PM
flitecontrol's Avatar
A rear tire lasts you 1 1/2 months on average? Why/what brand?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 14 (permalink) Old 02-09-2009, 11:38 PM
The Professor
lance328's Avatar
X2! Got me curious!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 14 (permalink) Old 02-10-2009, 08:41 AM
X2! Got me curious!
X3!!??
Are you drag racing your bike every weekend??
Ya really gotta spend a few more $$'s on a good tire that'll last longer (and be cheaper in the long run)
post #10 of 14 (permalink) Old 02-10-2009, 09:14 AM
x4 ?????
gcgoff is offline
