Engine not starting, Need help trouble shooting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 27 (permalink) Old 09-17-2017, 03:15 PM Thread Starter
Dirt to road
duraholiday's Avatar
91 Vn750. I had the engine out for a year. Changed the stator and stator rotor so took the engine cover off completely. Put everything back together. I have 1 year old iridium plugs and new gas. Cleaned the air filters and carb. It just turns over and over and over. No back firing, only one small hick up when spraying starting fluid into the plug ports and/or carb intake. Plugs have gas on them, sparkplugs spark. Battery does not hold a charge but i have jumper cables or boost box on the battery. I have also rejetted it up 2 sizes on each. Also degoated and put after market exhaust on.... but that shouldnt be the issue right?
Not sure what else to try.. any help would be appreciated.
Sent from my SM-G900P using Tapatalk
Project Bike 92 VN750
Days running: 0
Project Pictures http://s1116.photobucket.com/user/dieinghost/library/
Up coming Projects:
NOW- Getting it running....
Winter of 2015- Bobber Build
duraholiday is offline
post #2 of 27 (permalink) Old 09-17-2017, 04:16 PM Thread Starter
Dirt to road
Also with the bike on the kick stand, the bike tilted, gas is coming out of the tail pipe. Im starting to think the timing is off. The balance gear was rotated when the fly wheel, rotor, was off but the marks were lined back up.
Days running: 0
Up coming Projects:
post #3 of 27 (permalink) Old 09-17-2017, 10:32 PM
Sounds like a stuck float with the gas running out the pipes.
post #4 of 27 (permalink) Old 09-18-2017, 03:58 PM
x2 spockster - had same experience with gas out the pipes, and the error was in the carbs.
Brooklyn_Vulcan is offline
post #5 of 27 (permalink) Old 09-18-2017, 07:42 PM
try Wolfie's blowback method
post #6 of 27 (permalink) Old 10-18-2017, 09:38 PM Thread Starter
Dirt to road
Which is?
OleDirtyDoc likes this.
Days running: 0
Up coming Projects:
post #7 of 27 (permalink) Old 10-18-2017, 09:51 PM Thread Starter
Dirt to road
I think Im off 180 degrees. I have air and fuel blowing back through the carb so i think my intake valves are still open when compressing. Plus if I had a stuck float wouldnt it still back fire at least the other cylinder would fire? What are the odds that both my floats were stuck especially since I cleaned the carbs before putting the engine back on the frame.
So how do I check the timing? Theres the balance gear and the fly wheel (roter). They were the only things that moved when the engine was out so what could have gone wrong?
Days running: 0
Up coming Projects:
post #8 of 27 (permalink) Old 10-18-2017, 10:18 PM
Floats tend to stick most right after the carb has been dry.
Did you have the cams out or the timing chains off? Anything to do with the valve timing or mixing the cams up?
A compression test would show if it's compressing with intake valves open. You just get a low reading, if any. An air test would define it without a doubt, similar to a leakdown test, just without gauge readings.
You really can't alter the ignition timing any, not without re-engineering the pickup coils or the electronics. But ignition timing wouldn't send air back out the intake.
Intake valve stuck open is a possibility, but a huge stroke of bad luck to have it on two cylinders. All the exhaust mixes inside the goat belly, so just checking tailpipes isn't a good indicator of which cylinder has the problem.
With gas pouring out of the pipes, I doubt it could backfire on the flooded cylinder. Not saying it can't, but it's a lot less likely, and I'd want a fire extinguisher close just in case.
Mine would always start up on one cylinder, the idle was down by almost half when it did.
post #9 of 27 (permalink) Old 10-18-2017, 10:34 PM
If that's all, your timing is still fine, both ignition and valve timing.
If the marks were off on the balance gear, it would just shake violently, but still start and run.
The rotor is the part that determines ignition timing, and it only goes on one way. The valve timing can't change without removing the timing chains.
post #10 of 27 (permalink) Old 10-18-2017, 10:46 PM Thread Starter
Dirt to road
I did not touch anything but the fly wheel (stator rotor). The balance rotated when I took it off but i just rotated it back to line up the marks.
I know the valves are extremely dirty. I might change them now since the bike isnt running.
The pulser coils, i think they are called, are the 2 magnets by the stator correct? I bought used ones, could that be an issue?
How would I get the floats unstuck? I have never had a float stuck in any of my bikes after a carb clean before?
Days running: 0
Up coming Projects:
