Vulcan bogging out, help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-28-2017, 08:17 AM
Hello.
Your thread did not show up because you can't post photos if you're a new member....at least until you have posted 4-5 times first.
post #2 of 5 (permalink) Old 08-28-2017, 09:02 AM
1-get an AGM battery
2-check to see if it is flooding on either cylinder,and if so,try the Wolfie blowback method. it's a sticky in the carb section.
3-can you please give us an introduction in the newbie section?
post #3 of 5 (permalink) Old 08-28-2017, 08:29 PM
Did this problem just start, or exist for the whole "riding season" this year?
Are you running stock air filter setup, if so are they in good condition?
Everything doc said is a good start regardless. Have you ever serviced the carb? Did\Do you drain fuel from bowls during 'off season'? use stabilizer?
Have you check spark color? or done a plug read?
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #4 of 5 (permalink) Old 08-29-2017, 01:59 AM Thread Starter
Thanks for the replies guys and sorry about the picture I am new to forums in general. I am going to head over to the carb section and check out the sticky mentioned above and try out this blowback method. I never checked the spark plug because the Vulcan was starting without any issues but now you mentioned it I will be pulling that out and making sure it's nice and clean.
A few of the other things mentioned i'm not sure what they are so affter a little googling I will be back guys. I will also drop an introduction post.
Thanks
WozKawi is offline
