oil line hanging down - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-31-2009, 03:35 PM Thread Starter
Hi, I just got my '95 vn750 last week. I just got back from a ride and noticed my bike leaking. I looked underneath the bike and the line from the top of the oil container is hanging down, not connected to anything. Where should that line be connected to?
crossbred is offline
post #2 of 11 (permalink) Old 01-31-2009, 03:51 PM
Confused which line you are speaking of, give a better description, is it rubber tubeing, a metal line, or what, and exactly where is it coming from (top of the oil container?????) don't understand where that would be...
something is not right here, and someone here can help, may not be a problem at all though...
post #3 of 11 (permalink) Old 01-31-2009, 04:02 PM
Vintage bike addict
antiq's Avatar
It's likely a vent line. Post up a picture and we'll get it figured out.
Eleanor Roosevelt.
antiq is offline
post #4 of 11 (permalink) Old 01-31-2009, 04:14 PM
Oil tank???? The oil is in the engine.
Are you referring to the tank on the lower right side of the bike, behind a black (or sometimes chrome) cover, with a cap on top of it?
That's the coolant overflow tank. Hope you didn't put oil in there!!!
post #5 of 11 (permalink) Old 01-31-2009, 06:11 PM Thread Starter
yeah, thats the one. its the coolant tank. the line is a rubber tube coming out of the top. someone at a motorcycle shop said its probably the overflow too. wow, haha, im really glad i didn't put oil in there either! thanks!
post #6 of 11 (permalink) Old 01-31-2009, 06:25 PM
750Doug's Avatar
Crossbred, (really? I won't ask...)
Welcome to the group.
Do you have any pics of your new bike, and is this your first bike?
750Doug is offline
post #7 of 11 (permalink) Old 01-31-2009, 07:21 PM
So are we, good man!
Mastertech is offline
post #8 of 11 (permalink) Old 01-31-2009, 07:31 PM
The Professor
lance328's Avatar
That's one of those RARE "oil tanks" that use a special lubricant, I prefer propylene glycol but some prefer ethylene glycol. LOL
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 11 (permalink) Old 02-01-2009, 02:16 AM Thread Starter
yeah. this is my very first bike. im pretty excited!
as for whats going on with my bike right now, i'm not. so i now know that the leak is the coolant. the coolant was all empty, so i bought some and refilled it to see if and where it would leak. it leaks while im riding and a little for a little bit after. i took it for a little ride and i noticed my engine was overheating. so i went home and turned off my bike, and it was steaming/smoking (not really sure which one) under my bike. and i could hear it making an odd noise, so i opened the coolant cap and the coolant looked almost like it was boiling. now, i'm no mechanic, but i know this is really bad. what should i do? or not do?
thanks for helping me thus far, i really appreciate it!
post #10 of 11 (permalink) Old 02-01-2009, 04:16 AM
The Professor
lance328's Avatar
You could have a clogged radiator, bad thermostat, bad water pump impeller or just an air lock. To the left of the fil neck is the thermostat housing, to the left of that is a bleeder to remove air when filling. Open the bleeder and slowly fill untill coolant comes out of the bleeder. Make sure you use 50/50 coolant/distilled water and not pure coolant. If you have to drain there is a drain on the bottom front of the radiator. Did you notice if your fan came on while engine was hot?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
