Touching Up The Frame? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-31-2009, 11:36 AM Thread Starter
GuyP's Avatar
I did a search on the subject but couldn't find what I was looking for.
I have a few check that several spots of rust on my stock '93 frame and would like to repair them. Other than just sanding, neutralizing with phosphoric acid, priming and painting. What's everyone else doing to make it un-noticable? Technique? Type/Brand/Color of paint?
TIA
GuyP is offline
post #2 of 6 (permalink) Old 01-31-2009, 01:09 PM
ipfreely's Avatar
The last bike I touched up the frame on was a Honda Shadow. I wire brushed and sanded the frame to remove the rust, used black primer and painted it with gloss black touchup paint. I didnt remove the engine or anything that I didnt have to. Just take your time and cover \ mask anything that is in the way. If you get over spray on anything, a little thinner on a rag should remove it nicely.
Kuryakyn Flame Grips
Bar End helmet locks
Chrome / Gold "Live to Ride Mirrors"
Coastered, Shaved & Jetted
K&N Pod Air Filters
KisanTech headlamp & Taillight modulators
Iridium's
Leather Lyke Hard Bags
Voltmeter, Clock
Stebel Nautilus horn
Slipstreamer SS28
J&M CB Radio
Audiovox CCS-100 Electronic Cruise Control
Mustang Seat, Protac Drivers Backrest
And of course the obligatory stator replacement[/FONT]
ipfreely is offline
post #3 of 6 (permalink) Old 01-31-2009, 02:15 PM
Vintage bike addict
antiq's Avatar
I just wire brush. Then I use a soft 1" brush to apply Hammerite smooth gloss black paint.
Eleanor Roosevelt.
antiq is offline
post #4 of 6 (permalink) Old 01-31-2009, 03:45 PM Thread Starter
GuyP's Avatar
Does that pretty much match the factory Black powder coat?
Does any of the chain stores carry it?
GuyP is offline
post #5 of 6 (permalink) Old 01-31-2009, 04:43 PM
Vintage bike addict
antiq's Avatar
Fresh paint will differ just a bit but after it ages a bit it becomes hard to see. It seems to hold a better gloss than the stock coating. I get it at a local hardware store. One of those advertising Ace hardware. The Hammerite comes both in a smooth finish and a hammered finish and can be bought in rattle cans too. I like it because it's tough, slick, and no rust treatment is needed.
Eleanor Roosevelt.
antiq is offline
post #6 of 6 (permalink) Old 01-31-2009, 07:22 PM
The Professor
lance328's Avatar
The factory frames aren't powder caoted, just baked on acrylic enamel. You can clean the rust and apply a rust converter to neutralize any residule rust. Then sand prime and paint, but you will not get the same sheen or luster due to the degradation of the original finish.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
