cold weather problems? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-24-2009, 05:48 PM Thread Starter
Ba dum dum, ching...
Ron_G's Avatar
Today it was about 37 and sunny so I took her out for a ride. She seemed to start ok but where it usually starts to rev above 2K shortly after starting (which is when I back down the choke to keep her at about 1.5K until shes warm) I couldn't get her off choke. When I tried she would die. When I finally thought she was warm I took her around the block but she was running rough and sputtered between 2K and 3K. She smooths out above 3K but she's not done this before and I was wondering if it was the cold causing her to act up. Any ideas?
R
Yes, it's my mid-life crisis.
Sweet Jane...
http://images5a.snapfish.com/232323232%7Ffp63386%3Enu%3D457%3A%3E6%3C3%3E258%3E  WSNRCG%3D3345343785349nu0mrj
Ron_G is offline
post #2 of 7 (permalink) Old 01-24-2009, 06:27 PM
did it warm up fully? how did it act then, it needs choke for quite some time in 37
Mastertech is offline
post #3 of 7 (permalink) Old 01-24-2009, 06:52 PM
flitecontrol's Avatar
Got Sea Foam?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 7 (permalink) Old 01-24-2009, 07:19 PM
The Professor
lance328's Avatar
Originally Posted by Ron_G View Post
Today it was about 37 and sunny so I took her out for a ride. She seemed to start ok but where it usually starts to rev above 2K shortly after starting (which is when I back down the choke to keep her at about 1.5K until shes warm) I couldn't get her off choke. When I tried she would die. When I finally thought she was warm I took her around the block but she was running rough and sputtered between 2K and 3K. She's smooth out above 3K but she's not done this before and I was wondering if it was the cold causing her to act up. Any ideas?
R
Air is alot denser at 37 than at 65 which means you need more fuel for proper combustion at 37 intil the engine warms up. At cold temperatures the air molecules shrink allowing more air to occupy the same space causing a lean fuel condition. As the engine warms so does the incoming air and the air molecules expand requiring less fuel.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 7 (permalink) Old 01-25-2009, 04:18 PM
fergy's Avatar
You've probably gotten some moisture in the fuel system with the time off from riding and the warmer temps, especially if you haven't used seafoam in your fuel to help keep things stabilized. If not, get some in there asap and let it go to work. You'll be glad you did.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 7 (permalink) Old 01-25-2009, 06:43 PM Thread Starter
Ron_G's Avatar
I use seafoam on a regular basis however last time I filled the tank I ran out after about putting about an oz in the tank (label says about an oz per gal of fuel). That and keeping the choke on until it's fully warm might solve this problem. I'll try and let you know the results.
Thanks all for your input. I'd be up a creek without this group.
R
Sweet Jane...
Ron_G is offline
post #7 of 7 (permalink) Old 01-25-2009, 09:34 PM
Fire Ant's Avatar
My personal best for "cold" weather riding is a 25-ish mile ride to work at 27 degrees. When I start my bike in those temps, I have her on full choke and leave her there until her RPMs hit about 4k. Once that happens, I know that I can safely back off the choke (reducing the RPMs to around 1100) without worrying about her stalling. At those temps, waiting for her to hit 4k can take several minutes...
--FA
K.J. "Fire Ant" Lord
VROC #28807
Decatur, TX
'03 VN750 "Serenity"
Rear Turn Signal Relocation
Front Brake Replacement
Spline lube, per Fergy's excellent instructions (that he has posted around here somewhere)
Kevlar Clutch Plates
Metzeler ME880 Tires
Stebel Nautilus Air Horn
ACCTs Rebuilt
Saddlemen Explorer Seat
MCCTs Installed
Kuryakyn Wide Levers Installed
Fire Ant is offline
