Great....advice on this forum(??) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 11 (permalink) Old 07-06-2017, 04:05 PM Thread Starter
vulkan's Avatar
Damn ordered a new front tire but checked on proper stock size here on the forum saw a 100/90-19 so ordered that.Then checked the ACTUAL tire on my bike...its a 110/90-19!!Damn!!Shinko 712 Front Tire - 100/90H-19/Blackwall ordered.
vulkan is offline
post #2 of 11 (permalink) Old 07-06-2017, 04:13 PM
100 is the factory size. many upgrade to a 110 to help correct for the inaccurate speedo. either will work fine, only difference is the speedo will read slightly faster with smaller tire
michiganteddybear is offline
post #3 of 11 (permalink) Old 07-06-2017, 04:25 PM
ubertalldude's Avatar
It'll fit but your speedo will read higher than normal and you may have slightly twitchier handling. Any way to cancel and change the order? Usually tire stores online are pretty forgiving
ubertalldude is offline
post #4 of 11 (permalink) Old 07-06-2017, 04:25 PM Thread Starter
vulkan's Avatar
OK so the 110 verses 100...100 smaller...bigger??
vulkan is offline
post #5 of 11 (permalink) Old 07-06-2017, 04:53 PM
Damn it.I thought the smaller front tire made my bike faster
post #6 of 11 (permalink) Old 07-06-2017, 05:09 PM
the 110 is a wider cross section, but with the same aspect ratio, so it's a slightly wider and proportionally taller tire. This means it is ever-so-slightly more stable (probably imperceptible to most riders) and spins fewer revolutions per mile due to the greater circumference, so it will report a slightly lower speed to the speedometer (which reads high from the factory, so the "oversized" 110 tire corrects for that slightly)
I forgot 110 was the oversize, but the 100 will serve you just fine and you'll likely never notice the difference, so you have no need to worry.
post #7 of 11 (permalink) Old 07-06-2017, 05:09 PM
100 smaller
post #8 of 11 (permalink) Old 07-06-2017, 05:13 PM
Headbanger/Popes of Hell
ruger's Avatar
the 110 is wider/bigger. many on here believe it to be an upgrade. I myself like the 110 better.
the 100 is skinnier/smaller. also the stock size.
see this....https://www.vn750.com/forum/27-wheels...side-side.html
OleDirtyDoc likes this.
ruger is online now
post #9 of 11 (permalink) Old 07-06-2017, 05:50 PM
yes the 110 is ODD approved.by all of us but one.but what does he know, he never rides with us.he just sits in his little corner crocheting baby booties.
Hexadecimus likes this.
post #10 of 11 (permalink) Old 07-13-2017, 10:02 PM Thread Starter
vulkan's Avatar
Thanks...prolly went with that 110 because of this Forum...four years ago!!So its "my bad" I did not look further...its all good though!!Thanks.
Name:	Vulcan ordered front.jpg
vulkan is offline
