Throttle Stop Cable - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-16-2017, 08:43 PM Thread Starter
Throttle Stop Cable
So I went to adjust my idle some, running about 1350 fully warmed up, and my cable is broken. Is there any alternative to replace it with without buying the OEM cable? Not wanting to drop $85 on a new one.
Panic1982 is offline
post #2 of 6 (permalink) Old 06-16-2017, 09:24 PM
shouldn't pay more than $20 on a new cable.check eBay
post #3 of 6 (permalink) Old 06-17-2017, 09:24 AM Thread Starter
I did check ebay; none used on there. Seems all cost about $80 range for that 6inch cable.
post #4 of 6 (permalink) Old 06-17-2017, 09:45 AM
Check this out.
vn 750 throttle cable | eBay
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #5 of 6 (permalink) Old 06-17-2017, 11:32 AM Thread Starter
Its the idle cable, some reason they call it the "Throttle Stop". Kawasaki VN 750 VN750 vulcan 85-2000 screw throttle stop 16021-1112 genuine NOS | eBay
post #6 of 6 (permalink) Old 06-17-2017, 12:21 PM
Seems to me you could just bypass the thing with a proper sized bolt....you'd have to adjust the idle with a wrench, but really once you adjust it, you shouldn't need to again. May need a nut to make a stop.
