hard to/wont start after running/riding a while - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 18Likes
post #1 of 33 (permalink) Old 06-07-2017, 05:41 PM Thread Starter
clb3chey's Avatar
my 89' 750 has always been hard to get started after i ride a bit and turn it off ....if i go to the store or to get gas, it always is difficult to start,only does this when warmed up... It starts 1st time every time when cold, has a new battery and runs great when i ride otherwise.What is going on ?..i need advice please, thanks everyone...
clb3chey is offline
post #2 of 33 (permalink) Old 06-07-2017, 06:13 PM
Is it an AGM battery or wet cell?
What exactly do you do to start the bike?
Do a search for "pickup coil mod"
post #3 of 33 (permalink) Old 06-07-2017, 06:22 PM
Try choking it when you restart if it has sat a few minutes, mine cools off quick.
Mine also starts best if I don't open the throttle.
post #4 of 33 (permalink) Old 06-08-2017, 02:02 AM
Eagle Riders 4146
JimmyMac's Avatar
I bought my '03 last summer and had the very same problem. Drive a short distance and it was very hard to start. The last time it happened I was out gassing up, and the battery ran down before every getting it to fire up again. The people on here are a godsend! After reading through the threads I found a few possible causes, but settled on the suggestion that my wet-cell battery wasn't beefy enough and that I should invest in an AGM battery. I picked up the one listed below from O'Reilly for about $85 and the hard starting problem hasn't been an issue since. If you don't get this one just be sure to get one with 200+ cold cranking amps, and make sure you get one that has an "L" at the end, otherwise the posts will be reversed and the cables won't reach. Good luck!
Super Start Extreme Power Sport AGM - Battery
Line: SSB | Part # ETX15L
1 year limited warranty
UPC: 83996010826
Cold Cranking Amps (CCA): 220 CCA
Voltage (V): 12 Volt
Terminal Type: Top Post
Paulywog and chapmansat like this.
[FONT="Palatino Linotype"][SIZE="5"][SIZE="2"][FONT="Comic Sans MS"]"Sometimes you find yourself in the middle of nowhere; and sometimes, in the middle of nowhere, you find yourself."[/FONT][/SIZE][/SIZE][/FONT]
[I]'03 VN750 aka "Shelley"
42K Miles
Purchased July '16
Oil Changed - Shell Rotella 5W40
Radiator Flushed - Engine Ice
EMGO 19" Turnout Mufflers
Super Start AGM MF Battery (220 CCA)
K&N Air Filters - No Ear Shave
Stay tuned.....[/I]
[SIGPIC][/SIGPIC]
JimmyMac is offline
post #5 of 33 (permalink) Old 06-08-2017, 02:27 AM
mine did the same thing with a wet cell. used to strap a jump pack to the bike.rrrr rrrr rrrr rrrr BOOM!
JimmyMac likes this.
post #6 of 33 (permalink) Old 06-08-2017, 10:54 AM
ZmanInFl's Avatar
I had this exact same issue, I have a '06. Come to find out after cleaning the plug on my rectifier and checking into the pickup coil that solved most of it. It still does it at times but I have to really ride her far to muck up again. My last ride I did a 100 mile stretch with no problems. If your still full stock then relocating the essential electronics is a key also, keeps them from getting so hot and breaking out. These guys really have great ideas and are very knowledgeable and without them I would have been walking many times
CURRENT BABY: 2006 Vulcan VN750, 13k miles.
PREVIOUS Big BABIES: 77 Kawasaki KZ400, 88 Honda Hurricane 1000, 78 Yamaha XS650, 84 Honda Goldwing 1000, 86 Suzuki GS550L
PREVIOUS Lil Babies: 84 Honda Passport 70 (modified the heck out of it), 08 Yamaha Zuma FX50 (just sold)
ZmanInFl is offline
post #7 of 33 (permalink) Old 06-08-2017, 02:29 PM
Mcneuby's Avatar
Hard Starting
I have had several vn750's. the AGM battery was the answer as far as hard starting was concerned. That and I found it worked better if I didn't touch the throttle until it started to fire. I only chocked it when the weather was cold.
I have to quit looking at this forum or I might buy another one.
Ride Safe
Mcneuby
Paulywog, JimmyMac and chapmansat like this.
New to me 2004 15k Last liscened in 2011. Stock as they come.
Mcneuby is offline
post #8 of 33 (permalink) Old 07-16-2017, 05:29 PM
I'm a rider
One1's Avatar
A strong battery covers up a weak rectifier issue...... mostly. Always upgrade the battery when you can, but fixing the hot start issue in a case like this exact one is 90% regulator plug related. It likes to brown, burn, and blacken those connectors. Monthly cleaning and inspection is a really good idea on these bikes. One of the biggest tale tell signs of the issue is a dynamite stick of backfiring while trying to start it.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #9 of 33 (permalink) Old 07-16-2017, 07:17 PM
Thumbs up
On my 91 I put in an AGM battery and Iridium plugs. Cold starts or hot,I don't hold down on the start button,instead I just touch or "bump"the start button and it fires up after a few tries. Good luck.
OleDirtyDoc and JimmyMac like this.
Paulywog is offline
post #10 of 33 (permalink) Old 08-10-2017, 09:33 PM
Larry Oswald
Trying to understand
With respect to the new battery and R/R connector theories I fail to comprehend the mechanism here. Is the idea that the R/R causes the charge status of the battery to be weak OR does the R/R somehow short when it gets hot? As was mentioned above a great battery can mask the real problem ... which I still do not see. Comments solicited please.
Is the consensus that this is an electrical problem? Ignition maybe? Has anyone installed a voltmeter on their bike? Has anyone checked for spark when the bike is hot? Does a shaky battery weaken when hot?
LLHO39 is offline
