Lost Keys - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 16 (permalink) Old 02-05-2017, 10:12 PM Thread Starter
Raynor22's Avatar
Question Lost Keys
Couldn't find a thread on this, but I have lost my keys to my 1995 Vulcan 750 (yes I know, dumb to keep both keys on the same ring!). For whatever reason my VIN isn't in the Kawasaki system (I bought the bike from a private seller last year). So Kawasaki keys says they can't help me. I've taken it to a mechanic who says he can replace parts to install a new system with keys, but the parts will cost $390, that's not counting the labor. Any suggestions for what to do? I don't know if I could find someone who has a similar bike who would be willing to make a copy of their key and sell it to me, which would save me a ton of money, or if I need to keep pestering Kawasaki until I find a more reasonable solution. I don't want to sell the bike, so I'm open to any suggestions or ideas people might have. Thanks!
Live to Ride
Raynor22 is offline
post #2 of 16 (permalink) Old 02-05-2017, 11:31 PM
mayor of Narnia
minikrew's Avatar
take the helmet lock off and take it to a locksmith they can make you a key from that
new supetrapp mufflers
led turn lights
talked to wolfie got highway pegs
to late to bring back wolfie now ride on brother
degoated
new rear drive & splines lubed h-pipe installed riding on the darkside
minikrew is offline
post #3 of 16 (permalink) Old 02-05-2017, 11:37 PM
mayor of Narnia
minikrew's Avatar
and go to the noobie forum and make a intro before 2000 gets ya
OleDirtyDoc likes this.
led turn lights
degoated
minikrew is offline
post #4 of 16 (permalink) Old 02-05-2017, 11:46 PM
or me
Paulywog likes this.
post #5 of 16 (permalink) Old 02-06-2017, 11:09 AM
How do you take the helmet lock off without a key?
post #6 of 16 (permalink) Old 02-06-2017, 12:41 PM
call a traveling locksmith service.they can do it right on the bike.they show up at your house with a panel van and make the key right in your driveway
post #7 of 16 (permalink) Old 02-06-2017, 02:30 PM
mayor of Narnia
minikrew's Avatar
one small Philips screw and a small screwdriver not to hard
led turn lights
degoated
minikrew is offline
post #8 of 16 (permalink) Old 02-06-2017, 03:57 PM
The screw is loctited from the factory. You can't use a screwdriver unless you open the lock....which needs a key.
post #9 of 16 (permalink) Old 02-06-2017, 04:52 PM
Drew M.'s Avatar
if you take the helmet lock off, your key code is stamped on the back of it. it is a 5 digit code and contains numbers and letters. KM is correct, you do need the key to open the helmet lock so you can take it off. but the helmet lock is easy enough to pick. Of if you cant find anyone that can pick your helmet lock you can cut the bar out with a dremel or a hack saw. once you have your key code, anybody can look up the code and cut you a new key. new keys plus the cost of a new helmet lock (if you cut it open) is much cheaper than $400. Once you get your helmet lock off PM me and i can tell you where to look for your code.
and go check in!
Drew
'03 VN750 a little over 4300 miles
Spline lube
F&S Rear blinker relocation
F&S Luggage rack
Saddlebags
F&S Extended backrest
Mustang seat
F&S Engine guard
Plexifairing 3 windshield
KM style dash
LED everything + additional brake lights &
LED plate bolts
Drew M. is offline
post #10 of 16 (permalink) Old 02-06-2017, 06:37 PM
mayor of Narnia
minikrew's Avatar
k/m i went out and removed my lock before i posted back it took my maybe 5 min to remove it so it can be done
led turn lights
degoated
minikrew is offline
